The Young Effect, my gift to the free energy movement!
Started by captainpecan, November 16, 2008, 11:02:42 PM
0 Members and 38 Guests are viewing this topic.
MeltDown
I am not tearing things down, I am pointing out a flaw in your test.
Replace the arcing wire with a 2n3055 that is driven with a 555 set
up as a one shot. That would be a proper test that you could draw
some kind of conclusion from.
Otherwise, each time the connection makes and breaks, you send
another charge pump to the capacitor and one will expect it do charge
just like a capacitor will and just like yours did.
capthook
Quote from: capthook on November 17, 2008, 03:12:47 AM
I 100% disagree with your statement that energy is entering the system, and it is my opinion that what you are doing has a 0% chance of creating free energy.
When you refine your methods and contemplate it some more - you should come to the same conclusion.
Still in the (unrefined) sandbox I see.........
Quote from: captainpecan on November 17, 2008, 03:04:05 PM
Did I prove it? Some say yes, some say no.  I guess it really doesn't matter, because the real proof is going to happen when the self runners start popping up out of the woodwork!
Has the woodwork turned to sawdust yet?
Quote from: captainpecan on December 03, 2008, 04:34:25 AM
It is amazing how quick people jump up to tear things down. This time I think you should rethink how that voltage got there.
So if someone expressing an opinion that differs from you, they are bashing you?  And when you make a comment like "self runners start popping up out of the woodwork!" about your..... ahem.... tests..... you DESERVE NOT A BASHING BUT A THRASHING!
So lets see:
1. What is a spark....hmmmm HIGH VOLTAGE
2. What happens when you MAKE a spark........ see #1
3. You input 20volts @ 3.5amps (the rating of your powersupply) for 1 second: 70 wattseconds
4. You capture on your capacitor: .5(.0001x58x58) = 0.1682 wattseconds
So you managed to:
Do zero work while expending 99.99% of your applied power.
When can I run my car off of this 'technology'?   ::)
captainpecan
It appears youtube cuts frames out of video's.  You cant see the high voltage spikes on the multimeter, and cant see the sparks all the time.  Here are six back to back stills of individual frames that make it a little easier to see what is happening on the multimeter.  You can see the extremely high voltage spike coming off the coil just as the connection is broken.
captainpecan
Quote from: capthook on December 03, 2008, 05:41:04 AM
Many people have expressed opinions that differ from mine, and I do not see it as bashing at all.  But it is obvious those who have no respect for others.  Some people dont care to sift through all the troll dung, just to find someone trying to work in the right direction.  It seems funny though that certain people like you, who have absolutely nothing positive to add to this thread anymore, continue to hang around. I dont believe you have given even 1 suggestion as to how things could be improved.  All I've seen from you is flat out tear down.  You said your piece way back on page 1 about capacitors charging. You've said since page 1 that there is no free energy here. Stop wasting our time and yours by hanging around in here.  Move along now, there's nothing more for you to see here.
captainpecan
So you managed to:
First off, It's interesting you can come to a conclusion of exactly how much energy was lost in this test by figuring it took one full second for that millisecond pulse.  Oh, and let's get critical and measure exactly how much energy in the capacitor.  I dont think I mentioned anywhere in that video that it had anything to do with overunity either.  I took suggestions from others as to what I should test, for ways to send a low voltage into a higher voltage cap.  The goal was to charge a cap from the collapsing field to a higher voltage.  Interesting enough, I learned something from trying what IST suggested. I dont really care if you like it or not to be honest, I did exactly what I wanted to do in that video... Take another step forward in understanding how all this stuff can work together.
Where's your videos showing your work towards free energy?  Maybe everyone would like to pick your stuff apart too!
