Magnetic engine efficient accelerating magnet gate on youtube
Started by hartiberlin, November 18, 2008, 12:40:06 PM
TechStuf
QuoteSo I still disagree to the guys who say that the forces are symmetrical.
With the right iron core pieces inside the flux gate you can make such
a setup very asymmetrical and thus get acceleration into one direction.
Regards, Stefan
http://www.youtube.com/watch?v=TbqsWOK0uMo
Given that the best demonstration of the flux gate thus far has been given by Howard Johnson himself, I think it's fair to say that the vast majority of repeat attempts have mistaken force over time asymmetry for actual force asymmetry.  Those who've been stubborn enough to have bumped ceilings with HJ, have no doubt glimpsed past the event horizon into a veritable Laurentian abyssal of composite field complexities.  I think that if anyone working with magnets were to test the radius of actual field influence of each magnet, they may come away with a newfound respect for 'near surface' dynamics.   What appears more impressive with a composite field flux gate is the fact field asymmetry is more prevalent.  Again, I refer the reader back to Peregrinus.  A simple cone shaped neo is, by nature of it's existence, an asymmetrical field generator.
In no way do I feel that HJ's flux gate is a dead end.  Only that it is inefficient for the purposes of conventional power generation.  Now, as a vehicle for unconventional power generation, it's potential for efficiency looks much brighter.
HJ inspired the expression:  "90 degree rule"  referring to perpendicular field interactions as a basis for the flux gate research.  What becomes readily apparent is that the system prefers movement in one direction, but what is occuring is actually more complex.  Oversimplified, one might use an obtuse triangle for comparison.  Despite how it might feel, It takes the same amount of energy to push a weight up the left side as the right. Again, of course the triangle concept is not a direct analog....however, one gets the idea.
Howard appears to have produced a self powered unit, although I personally have never seen a demo of convincing run time. The timing of flux gate systems is so diabolical and misleading, that I'm fairly certain it ran finicky and produced very little, if any, usable power.
That's the potatoes of it.  The meat comes after one realizes that he need not settle on a wheel that barely turns.....and asks: what can be done with a wheel that provides so little resistance despite being spun at high speed with stator and rotor magnets in close proximity?
TS
“For the wisdom of this world is foolishness before God. For it is written, “He is THE ONE WHO CATCHES THE WISE IN THEIR CRAFTINESS” - 1 Corinthians 3:19
http://www.freemasonrywatch.org/sixpointedstar.html
http://www.youtube.com/watch?v=XBjOs-egFMs
http://www.youtube.com/watch?v=_WSGwnz7XpY
http://www.youtube.com/watch?v=l39XsMcyvgA
http://portland.indymedia.org/en/2004/09/297062.shtml
http://www.youtube.com/watch?v=JjjIy1DO0gs
We all have the choice to waste ourselves in rebellion or to gain wisdom.  Therefore, gain wisdom:
http://www.hisremnant.org/eby/articles/kingdom/twohands/twohandsof.html
Jdo300
For those interested in magnetic gates, check out this article here:
http://www.fdp.nu/free_energy.asp?book=90
Specifically, see the demo video here (also linked in the article):
http://www.fdp.nu/The%2090%20degree%20rule-filer/Arm%20Ramp%20Test.asf
This simple demo shows that the 90 degree gate is biased so that it takes less force to enter in one direction and much more to enter from the other direction. The kick out of the gate is the same in both cases though. The idea is that if you can stagger these gates in such a way that the fields do not interfere with each other and kill the gating effect, that it should be possible to produce a continuous rotating disk with a series of gates or at least a linear track.
God Bless,
Jason O
TechStuf
It appears that Stefan's site is being 'handled' and as such, it has proven difficult for me to post helpful information here.  Even my general inferences now seem to invoke the censors....
I may endeavor to get information to the web via another channel.
TS
hartiberlin
Quote from: TechStuf on November 21, 2008, 01:50:17 PM
TS
What do you mean by "handled" ?
I don´t censor anything, but just spam.
TechStuf
Several of my posts have disappeared upon hitting the post button, or the site won't load....or the site will load fine until I hit the reply button.  These kinds of harrassments have followed me from site to site, so when I use the term "handled" I am referencing TPTB.  Of course, when I am posting literally anything BUT important information....the posts usually go through.  Which seems indicative of real time go/no go analysis. The myriad 'intrigues' I've experienced go way beyond chance 'glitches', so I'm positive that my internet interactions are being 'handled' somewhere enroute.  I've had blue screens upon submitting posts, keyboard lockups, resulting in multiple driver reinstalls.  Hard drive failures, Mobo failures, monitor driver unloads....ALL at critical moments.
At this point, I think somebody should do a remake of the miniseries "V", only change a few subplot lines, names and characters and call it:
"Z"
TS
