Joule Thief
0 Members and 185 Guests are viewing this topic.
Cap-Z-ro
@ Mk1
One reason I think magnets are involved is the presence of 2 ring magnets in key element of the microwave oven.
I'm not sure what you mean by a 90 degree difference in the two forces though...I just have a laymans knowledge in this field.
Regards...
Mk1
@Cap-Z-ro
Think of a electromagnet like volt running in a wire around a core at 90 degrees from the core producing a magnet effect.
The reverse is also possible , the permanent magnet are the reason any conventional energy device are working, it needs some sort of energy to spin the magnet shaft therefore pulsing the stationary coil at 90 degree from it, In a transformer the coil that is connected to the wall socket the primary is not connected to the secondary output coil in any way, the energy is traveling by magnetic current (this is the hot stuff, it can't be calculated by a volt meter but still there), that magnetic current is tricky because you cant see it unless you use it .That probably why some people don't get it , it needs faith to try. So the transformer are 2 electromagnets on a single core first one sending and second receiving what its secondary coil is design for.
So the electric current runs at 90 degrees from the core , creating a magnetic current (you can not see but use)
Try this find some appliance  around the house that as a big transformer to work it , find a project transformer to test and place it on top of the other transformer and test the unconnected one , if its well placed it will pickup the voltage from the appliance transformer.
And the magnetron deserve its owns post, It is a really nice thing they got in the microwave, they should not lets us play with that
waves at the speed of light.
Cap-Z-ro
Thanks taking the time help me understand Mk1.
I keep getting the feeling that the concept behind the j/t could be scaled up to produce abundant energy...and magnets are involved in the set up somehow.
Regards...
Mk1
@Cap-Z-ro
In the jt the coil are like a electromagnet same as magnet except we take a little voltage to make them.Traditional system use magnets that passe quickly in front of a coil like in a alternator , the speeds is limited by the speed of the car motor and that changes the output .
So if we use electromagnet we can create that same effect but with electricity , so we don't have any moving parts like in the motor, and we can make the same effect by switching on and off magnets , Its the same effect as a bedini motor but without movement.
So i resume , In the joule thief we have , meg , tpu, bedini they are all cousins .
electricme
@all
I think I will try a little something a bit different perhapse.
I made a Tiny Winy Video on ultra low resolution so I can post it here.
I got a small CPU fan to work by my JT, but it only works for a few seconds.
Then I have to wait until the cap recharges, press the sw, and away it goes again.
What do you all think of this?
ist, where art thou, hibernation is over ist, come thou out and remark if you please.
jim electricme
