Joule Thief
0 Members and 142 Guests are viewing this topic.
gadgetmall
Quote from: guruji on November 22, 2009, 02:20:47 PM
Hi gadgetmall can one use a bank of batteries for that 650f cap instead. Another thing I found this kind of schematic maybe it would be of a use in your circuit gadgetmall.
Sorry for the rough diagram.
Thanks
No . Batteries have been tested for over 6 moths by everybody . check out Jesus thread feedback to source . they only capture Cool Electricity kind of but it does a Little work . If you know what you are doing you can actually burn batteries up with a bedini like i have done over and over. Ultra caps are Needed to capture AMPS on this circuit and i'm sticking with what works for the prize .later on we will have many new projects here . but for now free energy is here at last for real . Any replication anyone does needs to be what i used . you wont see it with surecap or batteries with this standard JT . i already did those test for you .I am redoing Experiment 1 with the AA battery and also experiment 2 with nothing but ultracaps AGAIN for you guys untile some one repets My exact replication i don't know what else to do but enjoy my new AA powered heater /light . i am building a small overunity circuit groundloop made  so this device is self sustaining as well . BIG TIME .. Don't believe the ney Sayers i know what i am talking about from the previous tests .
Gadget
gadgetmall
Quote from: jadaro2600 on November 22, 2009, 02:16:55 PM
@jeanna,
thanks for this confirmation.  I'll be testing some circuits later today, maybe with better results.
@gadget, i'm not sure how you're seeing past the fact that one side is charging the other directly ( by current ) and indirectly ( by voltage )...if I had the ultracaps, I would gladly test this idea.  BTW, how are you limiting the voltage to tolerable limits?
Dont know All i know is one wire from the charged bcap charges the run in a 5 second burst . Same effect can be seen on all my Bedini Circuits .
guruji
No I meant a bank of caps no batteries ;D I don't know why I said batteries.
Ok with a bank of caps with same voltage it would be good I think no?
Quote from: gadgetmall on November 22, 2009, 03:08:51 PM
Gadget
gadgetmall
Quote from: guruji on November 22, 2009, 05:09:05 PM
Of regular capacitors . Not sure . This has also been tried for other contributing members with varying results . I do NOT think you can run nichrome heating elements on regular caps  . there is not enough farads for the time needed to heat it . I am sure they will charge up and fast though. . try it :) there are way better cap charger Jt circuits . I just wanted to demonstrate a simple one will do the job  BIG TIME Mine work though and this is no BULL . thank you for your interest again .
Gadget .
resonanceman
Quote from: poynt99 on November 21, 2009, 07:30:40 PM
jeanna and gadget,
If you moved the operating frequency of this device way up there in the MHz, it might be possible to have it work without any core at all. However, in this case all 3 windings would have to be wound tri-filar.
poynt99
I am sure   you are right in  theory.
The  problem  is  JTs don't always follow  the  rules.
That  is probably  why  this thread  is  filled  with  posts  of mostly self taught   expermenters .
Quite a few people  tried many  different kinds of cores  and even no core at all .
If you have made  a few JTs    I have one for you to try .
Take at least 6 ft  of  twisted  pair wire.    I used  wire from  a  Cat5 cable.
Connect   the start  of one wire of  the twisted  pair  with the end of  the other . Just like it  was a standard JT coil.
Hook  up  a pot for  a base  resistor ...... and  connect  a transistor and a battery ......and just like magic  .........you have a working JT
I agree at first glance  it looks like    a secondary on this kind  of  JT would have  to  be  wound  trifilar ...........but  have you ever made a  primary  for a JT  with a twisted pair ?
If  you have a low perm toroid  it just takes a few  wraps of the twisted pair ........so ...... it only takes a few wraps  of the  twisted  pair to  add a toroid   to   our previously no  core  JT .
I do not know  how many  toroids  can be added  to   this kind  of JT .........I had  10  going at one point .
gary
