Joule Thief
0 Members and 181 Guests are viewing this topic.
innovation_station
ooo i dont think so ...
;D
not if your plan is a portable device ...   ;D
6 or 8 inchis is lots ... lol
ist! im sure you have seen the sm17  8) it  could be set up in such a mannor ...  stacked rings to receive ...   8) transmitt from center ...
have you tryed the neon just around your core ..  then imagine the reconnect on npn and pnp in sync..  as the transmitter ...  :o :o  useing the cores ...  and radating outward!   i bet you got to bang them really fast for it to spew...  lol   sounds bad ..  but i beleave it to be the case ... lol  ;D
you could get crazy as sm did collect the fly back and put it through the out side collector rings first  and use the radiateing antannas to intrupt it or collect from radiaring via tuned loop coils .. and add that with the colpase ...  10 million ways   hence why it took me years to get a handle on it ...  was NO EASY JOB...  :)
jeanna
Quote from: innovation_station on November 27, 2009, 12:01:02 AM
;D
I am pretty lost here.
I do think if you stack 2 of these on top of each other you could get 3 times the power, but I do not think we are talking about the same thing.
Yes, and nothing happened here.
A long time ago, I was trying to light a neon on a coil core and the neon would only light when it was in a certain place. I was convinced it was transmitting a lot.
I am sorry, ist.
I just do not know enough about this to be able to follow what you are saying.
BUT wait a year...
If I learn as much this coming year as I did last year, I will surely be able to follow what you are saying.  :)
jeanna
innovation_station
dont worry i got me all winter to build so i will build this too
much can be learned from simple tests ..
and your so good at them
william
freq maybe too low ...  or air core or plastic im sure better results are gained ..
but fast enough freq on a 1 inch it will spew   and then you still get big spikes that get sent through  collectors
J  what bout a magnet ....  :D :D :D :D  on the core ...
freepow
 :)Hello All...
    I experimented with an EER made with  1x copper pipe 19.75 inch long driven into ground
    and  1x thin solid steel rod 19.75 inch long driven into ground,  I tried distances of  40 feet, 21 feet,
    10 feet,  3 feet,  2 inhes  between the + and -
    results were the best at around 20-21 feet with highest current mA's  Not sure why though !
    Also I have a small array of 7 EER cells connected in series and added 2 more to equal 9 total,
    I have been charging a  55 Farad 2.5v super cap for approx 18 hours and my super cap shows...
    4.02 Amps  at .657 volts DC, but when connected to DMM, the cap runs down in mA's quickly,
    how do you stop the mA's from running out of cap so quickly - because I would like to use it
    on my Joule-Thief
    Or is it better to leave the cap connected permanently to the EER array and connect the Joule Thief
    to the cap...meaning the EER will keep charging the cap while i'm using the cap in the Joule Thief ?
    Could someone point me in the right direction please
innovation_station
welcome ...
intresting
look to wood henge...    ;)
i bet  i know ... you need rings... .. of them  at harmonics ..
use the golden spiral ..  place  rods at nodes .. . in 2 locations   useing oppsite spirals inward and outward ...
verry much like  my sign
ra!
yes i have solved those things some what too....
i have become addicted to solveing and building things ...
damm near time to get a relationship ...
naw....  single is ok ...   :)
w
