Joule Thief
0 Members and 187 Guests are viewing this topic.
gadgetmall
Quote from: Mk1 on November 27, 2009, 06:02:57 PM
@all
I also know this now ...
What could i have new to say ?
Nut much , but if i was to try this i would first try to find the best gauge for the jt side (bigger wire ) then try the match them gram for gram , since they will have the same mass and materiel they will share resonance at any freq.
The smaller you go on the secondary side , bigger resistance higher turn ratio for mass , same mass smaller gauge .
I think this will make sure that the current is not lost due to unmatched weight ...
Depending on the winding direction you get different sine wave .
Winding rotation direction , can help setting kick generation (+or-), when working with multiple core.
I hope this will help
Mark
I always work on lowest miilamp input .Mark, being were flashing to the past maybe post the best cap charger you made . this is second stage Level two . how fast can we charge LARGE  super /ultra caps .
Gadget
Mk1
@gadget
You know it ...
Many turns on the jt side usually reduces the amp needed, i think the longer they are more chances to trap some energy within the coil between kick .
When i us the short ones is to make insure that the will be flushed out.
I believe that way the kick is not slowed down from the slow emptying of the longer ones .
So i do it to get a clearer kick.
I hope this makes sense to you .
I did get really low mili amps input on both types .
Now the same mass issue , you have the two jt coils kicking , how much energy can be stored in a coil(like a cap) the secondary needs to have the same potential , to minimize the losses .
That could be done many ways but the coils are from the same material and same weight , will have the same natural resonant response at any freq .
Like guitar strings tuned together pick one the other will move , if you had 2 exact same diameter strings you can tune them to any note pick one and the other will react much more violently , you get the idea ?
I still have not used your tank circuit .
I study coils for now ,lol i will get to other stuff like trany and circuit soon.
Mark
The kick is the same but the the loses form the secondary close to eliminated .
Edit btw i don't super caps or any thing close to it , but any cap will do.
you test for speed , smaller cap help wit faster evolution waiting over 10h to get results is my thing , but i can also compare the secondary  output compared to the pickup .
xee2
@ jeanna
Quote from: jeanna on November 27, 2009, 05:33:28 PM
Thanks xee2,
I was there yesterday, but I was unable to find a starting point of reference.
The tor-60 was not one of their numbers, because they discontinued it, and the dimensions 3.38" are no longer used for the same reason, and I don't have enough info to start.
You were the person who wrote way back what the mu value for this toroid is.
I did not save that,
I am glad you have shown up today.
What is the mu value for that bog toroid?
thank you,
jeanna
Part number for the 3.38" diameter toroid is:  OW48613TC which is their W material.
Most of the data I have was in the design guide which use to be at following URL (but now must have a different address for a new guide). This is the old URL which does not work now for me: http://www.mag-inc.com/ferrites/fc601.asp
Here is some data:
Mk1
Next step in basic jt true ringing .
Find a core made for metal ring , not any toroid shape !
You hang it from a string then hit it with something hard , if it doesn't make a sound you can hear then find another one for now .
One you got one connect a microphone to your scope , find the ring freq.
Built the jt with that precise freq in mind , then ring it !
innovation_station
love it !  ;D
well said!  ;D
ist!
mk1 you realize im gonna have to make a video of this now ... lol
i was just given a 1000 foot spool of 14ga solid coated green wire ..  i have like 40 of those steel cores ..  i will bang 1 and do as you reccomend ...
;D ;D ;D ;D
