Joule Thief
0 Members and 234 Guests are viewing this topic.
jadaro2600
I'm wondering If a higher frequency becomes more sensitive to interference in the toroid.  Isn't it reasonable to deduce that a higher frequency will have less current from the primary flowing through it?
Quote from: jeanna on November 28, 2009, 07:32:37 PM
I think it is funny you ask, jadaro.
I do not why you say what you do about stray inductors... so I will have to see what naudin says.
jeanna
By 'stray', I should say strategically placed. :)
You may also note that the extra inductors will pick up 'signals' from the toroid or the mandatory inductors... placing them at 90 degrees to one another should void this, or make its interference negligible ..without a toroid, placement is obvious, but with one, an obvious placement becomes more non-obvious.
I just had an interesting thought about the pre-fab inductors, placing two as normal and one off the emitter may result in a higher junction capacitance across B-E; I wonder what this will do.
( off to test )...and this seems to nullify the process unless I use a very small inductor.
xee2
@ jeanna,
Quote from: jeanna on November 28, 2009, 08:19:14 PM
I see the diode in your diagram.
Is that needed for the light to work?
Yes. Bulb does not light without diode. I am not sure why.
I have not tried adding more bulbs.
jadaro2600
Quote from: xee2 on November 28, 2009, 08:48:15 PM
@ jeanna,
The light bulb, is it ~3 ohms at rest, or is it ~3 ohms when lit? ...the resistance should go up when it's lit ( regardless of the what value the initial resistance is ).
xee2
Quote from: jadaro2600 on November 28, 2009, 08:55:34 PM
3.2 ohms cold.
jeanna
I found some K values.
xee2, Is the K the same as the u?
oops mixed cm's with inches
edit:
biggo K= 4935
Tor-23 K= 840
Tor-61 K=6140
Tor-53K=9150
jeanna
