Joule Thief
0 Members and 139 Guests are viewing this topic.
xee2
@ kooler
Good thing I bought 50 of these bulbs. The first one now has a vaporized filament that made a very bright flash, like a camera flash, when used in this circuit.
EDIT: drawing is wrong, they are actually 25 amp pulses (before the bulb blows).
jeanna
Wow, xee2, maybe you need more in series!
That is cool to have that kind of problem with a filament light.
@All,
I just modded the 13w cfl I bought the other day but didn't use.
...then the 10wcfl I bought today so I might have a true replication of lidmotor's jeanna's light.
They are both a lot brighter than the 20w, but they shed no more apparent light in the room than it does.
I cannot put these in series at all.
So, there can be only 1 cfl per circuit so far.
I am glad I did this, because I am now getting the range of dimming that he was getting from the 20 ohm rs dimmer switch at the + battery end.
I will do a duration test on this one as well.
I got 2 alkalines with my new camera and this will give one of them a job to do.
jeanna
Pirate88179
Jeanna:
Thanks again for that link.  I ordered 1/2 pound of mag wire (28 gauge, 1 red one green)  I think this will work just fine because, in the specs, the "newbie" wire has a much thicker insulation for beginners to wind with to prevent shorts.  Now, I don't know the dielectric strength of the urethane insulation (I guess I could look it up) but, simply, thicker is better to insulate high voltage at whatever value.  I think this will work great.  My primary is going to be insulated solid copper wire (low resistance) 20 gauge that I bought by mistake a while back thinking it was stranded.
My Jeanna Light will be running soon!  (I hope)  today, I also bought a 13 watt cfl for my box.  That was the smallest the store had.
jeanna
Quote from: Pirate88179 on November 30, 2009, 10:53:24 PM
Jeanna:
It may be the reason I had no problem with the over 1400v I was getting the other day,?
Quote...
Excellent!
Now, I am waiting for the box.
If it is a good one, I will share the specs.
I hope to see a picture of this tonight!
jeanna
gadgetmall
Quote from: xee2 on November 30, 2009, 07:41:14 PM
@ kooler
Xee2 Very Nice . I have to ask what is being drained from the battery . Its got to be over 300 milliamps . In this case a 2000mah battery will only last a few hours . No ? What would be the advantage Verse running the bulb directly with the AA battery ?
