Joule Thief
0 Members and 99 Guests are viewing this topic.
jeanna
Nice ist,
It appears that there is NO iron in this.
I would ask you to confirm that the white wire is copper?
@xee2,
This is a good suggestion.
With my leds, I was shining them sideways onto a white paper to see how far the light was strongly spread on the paper.
Maybe we CAN come up with some of our own standards.
Thanks for that suggestion.
Also, I wanted to add my answer to the question you posed the other day.
My tip transistors do NOT fit easily into the holes of my breadboard either.
I jammed one into the 3 holes expanding the plastic. My plan is to always use the same 3 expanded plastic holes for this kind of transistor.
thank you,
jeanna
innovation_station
yes it is copper... all copper ... this is a tpu...
thank you ..
it can have iron or a feroite toroide in the center .... lol
this is a true eather pump tpu ...
ist!
output of the jt goes to the input of the big coil then out to the load ...  i use the magnetics produced from the jt to pump the colapse from the jt .. all of  it is mass to mass tuned  to there is resonance by 90 deg too  plus ...  i can add a trigger .. for a magnet swipe if i want .. i like it simple tho ..
this ring will radiate electromagnetics .. inside on the big coil and out side away from the torous pancake ..  it is a push small and pull big  that induces its self on the way out to do work ..
can run on a aa
my next design will be designed to ramp up ... this one squeezes  and  and radiates ..
it is looking good ... im surprized .. im 2/3 done second layer
ok i got it all wound  it worked out to 2 full layers around and 2/3 of another layer
so to level out the coil i will wind a bifillar picup mk2 style .. the out to a bridge...
resonanceman
Quote from: innovation_station on December 04, 2009, 02:54:04 PM
IST
Are  you  saying that  this is  the  primarys for  a JT ?
gary
jadaro2600
Quote from: innovation_station on December 04, 2009, 11:22:15 AM
how about the 369 ac unit....
how about 2 pancakes .. and a feroite core .. reconnect happins on 9 in the collector coil..
i have 1000 ways to the same .. answer
hummmm
As usual, it's quite a work of art.
Say, there should be a section for solenoid winding.. :)
innovation_station
Quote from: resonanceman on December 04, 2009, 04:03:57 PM
IST
gary
the jt is the 2 speeker wires wound in a torus ... out put of jt .. the 5 turn collector ... then it workes togather ... the device ... as the jt breakes the connection the colector pumps it turns on agin..  and induces in collector .. you turn it off it pumps collector ...  this is why it is a pump ... and it pumps THE GOOD STUFF...  just like my heart it pumps LOVE!
see  the genuis in simplisity...
w815
