Joule Thief
0 Members and 64 Guests are viewing this topic.
PaulLowrance
Here's my results of testing gadgetmalls circuit, or at least the closest I can presently get to it. I don't have his toroid, but I'm using a good toroid with high permeability.
The previous quick & dirty method that I used is not to be taken seriously, but this method has the potential of being very accurate. The method consist of using a resistor for the load, and measuring the R's temperature, which we'll call Tr. Then doing the control experiment, which consists of connecting the resistor directly to a power supply, and then increasing the current until the resistor temperature stabilizes at Tr.
An elaborate setup would use a closed system that maintains a fixed temperature. I did not go that far. Also I did not dig out the ridiculously sensitive temperature equipment.
A 100 ohm carbon resistor was used as the load. The voltage across the JT was 1.559 volts DC, and the current was 74.3mA DC, for a total of 116mW. The control experiment showed that it took only 93.3mW to bring the resistor to the same temperature.
This comes to 80.4% efficient.
This JT was about 80% efficient, but maybe there's some tweaks to improve this?
Regards,
Paul
gadgetmall
Quote from: PaulLowrance on December 08, 2009, 08:20:45 PM
Regards,
Paul
I haven't hooked  a scope to it yet but  ground the grouns and use a 900k resistor . that should not load the jt at all . Also the Diode is converting half the spikes to voltage . If you read the Ce with a meter you only see about 2.5 volts . put the diode on and it should be about 21 volts , Put another diode on the emmiter and you should see about 25 volts  . put a bridge  on the Eb and you see about 30 volts . As i said before i read The current with a 1 ohm resistor in series with the battery and adjust it 13 ma to get the above readings . IF your toroid is close to the same permeability then you should see at least these volts if not higher @ 13 ma draw . ..  My lowest Jt is pulling 0.80 milliamps  @ 0.18volts and runs 4 white leds in parallel . This one runs all the time 24 7 now since i built it . It uses an obsolete transistor and a true museum piece  HEP 638 . I found one on ebay a few weeks ago in the original box and bid 50 dollars on it . it went for 220.00 Us  :(  So this transistor is extremely Valuable germanium . Most of the germanium i sold to cheap . Some that Jeanna has are worth 100's of dollars i found out later ..  there is only one on the internet here http://www.mistersprockets.com/hep638-p-20142.html
Its a fake ,a cross no where near the value  or the guy has no idea whats its worth . you can easily make 5 times that
ALso It's so rare there is no spec sheet on the internet at all /
Gadget
Pirate88179
Paul:
Great testing idea.  Where were you getting the 1.55 volts from?  Was that the input from a battery?  If that was your output, it should be somewhere way higher than that.  The basic JT in its simple form should put out around 15-30 volts depending upon how you make it.  Input on this could be anywhere from 1.5 volts down to about .35 volts.
jadaro2600
The circuit goes into resonance rather quickly, it's working to its specifications.. I assume you are tuning it to optimum output?
The circuit will still be in resonance, I think what we're trying to assume here is that tuning is the key, not resonance.  The circuit will go into whatever resonance it's been adjusted for..
i.e. "Resonance at configuration X vs resonance at configuration Y" ...etc.
Is there a transistor that will open the Source-Drain channel when a voltage is applied?
Quote from: jadaro2600 on December 08, 2009, 09:29:33 PM
This is true but it doesn't mean it's optimal, if you hit the toroid and record the sound with a microphone it might peak at a certain frequency this is its natural vibration that you would like to work towards. Electrical frequency of the circuit depends on saturation level of either toroid or transistor.
I think you're looking for mosfets.
