Joule Thief
0 Members and 134 Guests are viewing this topic.
innovation_station
Quote from: jeanna on December 19, 2009, 08:33:50 PM
How do you GET the crystal to squeeze in your circuit??
It was so interesting to see the squeezed crystal making multiple rounds of spikes.
I have been looking for the video I made.
I will turn on the other computer. I hope it is there.
thank you,
jeanna
j
there a number of ways you can do this ..  the ring design i spoke of earlyer ..  was a encased crystal  for electrical use ...  i would wind a coil over that style unit ...
if a true crystal is used ..  many methods may be applyed ..
be this knowen ...
for right now ill leave this here ... !!!!!!!
try a crystal to charge a cap BY YOUR BODY ELECTRICTY BY TOUCH YOU WILL BE SURPRIZED !
thank you
w
jeanna
I went back.
I must have made a better connection or else the input battery was dead-ish when I started, because those same 100 turns is making 1200 volts!
Here is what happened:
I had forgotten to measure the amps draw.
[I believe the amps draw is only about the take of the transistor and a measure of how long it is on in the process,
but I dutifully measure it anyway, but this time I forgot.]
When I went back, the circuit just did nothing... then I added a fresher battery and the volts went off the chart to 1200v and the amps draw is around 140mA.
Just to celebrate I took this picture:
twoBrudders  :D
jeanna
innovation_station
I HAD WICKET RESULTS .. SO THE SCOPE SAYS ..
I think i got a super simple unit ...  it is wound the same a j coil but this is in a transformer .. similar any way but it dont matter .. i jted it .. than dioded 1 side then i switch back and forth ..  i need a switch that can do this ...
this with j 's coil and lookie lookie...  : )
i made 2 videos ..
ist
http://www.youtube.com/watch?v=HdnV2cWgqBM
got the magnet the right way and in the right spot ...  changed the super drained c with a fully charged aa the gadget standard!  energizer 2500maH any how it works better scope 10v/d
Magluvin
Hi all
Was discussing with my good buddy Zeropoint at YT about using a JT with the pulse motors we mess with. Lets say we store the BEMF of the pulse motor to a large cap, Ultra, maybe not even so big, then use the JT to take that to charge the drive battery. As of now, If we just try to dump the stored bemf to the drive bat, we are not getting all of the power stored in the storage cap to the bat if the cap gets to or below the bat voltage, where if we use a JT, we can make use of that energy that is in the cap at voltage levels that are below the bat level. Does that make sense?
Thanks
Magluvin
Pirate88179
Mag:
You can run a Bedini type motor from the b-caps and get rid of the batteries all together.  I am not saying it will run forever or anything but, the caps pick-up the back emf spikes in a more efficient manner than do batteries from my experience, for whatever that is worth.
