Joule Thief
0 Members and 123 Guests are viewing this topic.
xee2
The first testing with my new coil is disappointing. The output voltage is only a little over 1000 volts and the CFL is hardly any brighter than with the 80 turn pickup coil (but it does seem a bit brighter). I need to figure out why the output voltage is not higher.
Pirate88179
Xee2:
Welcome to my world.  Your light (given the differences in exposures from cameras) appears to be about as bright as mine.  Remember I used 2 toroids stacked together so when I wound 330 turns (give or take) I have a lot more wire there than on a single toroid.
When I see Jeanna's, and others photos, i am thinking, why did I use 2 toroids and all that wire as this does not seem any brighter, and maybe not even as bright, as what they are doing.
So, at this time, I can not recommend using 2 toroids as I have not seen a huge gain from this, or any gain really. I am not done tuning yet but, I don't see it being a big breakthrough at this point.  I was just glad to be able to be shocked by it when I was not before.  But, maybe this lower freq. is not what we want?  I would guess that the lower freq. will allow longer battery life as it is not turning on and off so fast but, I really don't know.
Later, when I get back from a job, I will continue with my tuning and see what happens.  I don't expect any order of magnitude increases though.
tysb3
now climbing to 1.276V.
the battary NI-CD AA700mAh recharge itself !!!!!!!!!!!!
I cant belive my eys. all parts from tv, from skip. I have only multimetter, breadbord and soldering tools.
I cant ajust properly it, but its gooooooooo
kooler
tysb3
i think i might build your circuit.. if you don't mind
i tried the same feedback on my second stage of my circuit .. but it puts out to much
it over runs the rest of my primany circuit.. burning the tansistor
i like what i see on your circuit.. what r the cap values at the feedback...
thanks
tysb3
@ kooler
from picup coil capacitor is M .55J,
from collector 10.0 mkf
its need to play with this caps to inproove JT
transistor is D1885 from tv line transformer
