Joule Thief
0 Members and 138 Guests are viewing this topic.
guruji
Quote from: tysb3 on December 21, 2009, 10:30:40 PM
now climbing to 1.276V.
the battary NI-CD AA700mAh recharge itself !!!!!!!!!!!!
I cant belive my eys. all parts from tv, from skip. I have only multimetter, breadbord and soldering tools.
I cant ajust properly it, but its gooooooooo
Hi Tysb3 thanks for sharing what transistor you're using?
Thanks
xee2
I graphed some data from JT I have built. It seems like there is not much point in using more than about 150 turns. I plan to add another data point at about 150 turns. I think this would be a valuable thing for jeanna to check me on. She is good at catching my mistakes. This data is with 2 base and 10 collector turns and a 2N3055 transistor.
EDIT: This result may be due to not having enough battery current. I wll try to test that.
EDIT: Using 2 D-cells and a 10,000 uF capacitor in parallel for a power source pushed to voltage with 250 turns up to 701 volts. So there is some performance limitation due to battery current, but not enough to be the main cause.
xee2 have you tried a higher current rated transistor? I think jeanna's big succes has to do with this, more current = more magnetism = bigger collapse. That is if transistor gets saturated before the core does.
xee2
Quote from: broli on December 22, 2009, 02:34:10 PM
Yes. More current will produce higher output voltage until something saturates.
This was a test of voltage vs turns with everything else constant. Not a test to see how much voltage I could get. The point is that it seems like there is a diminishing return for adding more turns.
EDIT: I know I can get over 1000 volts out using the toroid and the same transistor, so I do not think these test results are due to saturating the core or transistor. But, I also do not understand why the voltage is being limited. In a normal transformer the voltage keeps increasing with turns until the core saturates. I had expected that to be the case for the JT also, but it does not seem like the JT works that way. Of course my data might be bad.
tysb3
@ guruji
transistor is D1885 from tv's line transformer
