Joule Thief
0 Members and 182 Guests are viewing this topic.
xee2
Well this doesn't make sense. My test results go the opposite way from jeanna's.
Mk1
@xee
I see one or two problems with your data . First the diode limit is 1000v after that they are unreliable .
Second , you use fix resistor value , i usually use a pot to find the highest voltage or current depending on the test .
So if i change anything , i re tune it , the battery goes down same thing.
Those are my observation .
Mark
@jeanna
What is the wire size you use on the jt tested.
Same question for Xee
jeanna
Quote from: Mk1 on December 23, 2009, 07:03:22 PM
@jeanna
On the
big Gold
2T,7-10T
That wire was 24 awg
The 330T of gold was 26awg which I bought from gobrushless.
It is the same size as the green wire from RS.
@xee2,
You are right that is very strange.
I bet it is the transistor.
I remember you told me to look to the transistor once and last week I had a few different kinds of transistors and just changed nothing but that element and the difference was hundreds of volts and thousands of hz,
the transistors were:
2N3904
TIP31
TIP31C
TIP3055
The little one was the low one.
It also used many fewer mA
Which is why I think the transistor is what is determining the amps draw, and not the wires.
So, if there is no other way to read your output but through a diode cap arrangement you will be limited in your test results.
You may have the results but not be able to show it.
I wonder how well the cfl goes on when you have the 2T6T which I never even tried to scope.
thank you,
RS had another TIP31 and TIP3055. I bought both.
My volts are up from 39v to 111v on the new transistor, but the other day this gave me 350v and I cannot believe my eyes.  :o
jeanna
xee2
@ Mk1
@xee
Mark
@jeanna
All wire is #26. There are actually 2 diodes in series.
Mk1
Quote from: xee2 on December 23, 2009, 07:23:14 PM
@ Mk1
thank for the clarification , There is still the fix resistor value i wonder about jeanna?
Also i have to say i don't like 26 on the jt side , i always use 22 it works so much better , i don't know it its the size or insulation making a space between the wire and the toroid .
Mark
