Joule Thief
0 Members and 179 Guests are viewing this topic.
gadgetmall
I have a solution . Cast them in Clear lucite ! then sand the top ! the top will be frosted glow Bright and reflect the light on the clear sides thus amplifying the light and at the same time difusing the eye shattering beam !
gadget
Pirate88179
Gadget:
That sounds like a great idea there.  Maybe even have a cast square on top where the topside is sanded and the light then runs around and exits around all the edges...or a disk might be even better.  Many things to try...so little time.
kooler
@ xee2
if you notice the frequency of the scr changes with the resistance of the coil you use
light bulb... ign coil... flyback coil crt....the mot
it will charge two mot caps in a instance.. with a mot hooked up..
flyback coil ..crt.. is kool cause if you hook it backwards it changes the polarity of he coil
and you can feel a kool breeze off the high tension lead like a ion generator
xee2
Hi kooler
Quote from: kooler on December 27, 2009, 09:48:40 PM
@ xee2
TV flyback transformers usually have HV diodes in them that prevent getting reverse polarity out of the coil. They are also not made for high current, so this circuit may destroy them. But I am probably overly cautious about destroying transformers.
The frequency should be primarily set by the JT output power and the value of the capacitor.
innovation_station
its always good to kool things down ... eh kooler! lol
J
had an idea for you golden coil ! and i think you might quite enjoy it !   as it is the CENTER PEICE!
ok
now ... make a new job for you coil  we know it blowes up 1000's of leds ... if you want it to   it lites cfls it charges caps .... hummmm
lol   see where im going .. ?   use your secondary to recharge source draw from trigger colapse and with the tip 122 127 ..  add feed back ..  just a LOW VOLTAGE FEEDBACK....  use high ones as output ..  to pass on to cap bank... THEN WHEN DRIVEING BANK IS RECHARGED as it will run with gain ...  put an over flow and redirrect to output cap bank ... use the gadget solars to orgonally charge it ...
look mom no batteries ... lol
ist!
btw i DID NOT DEMO LOW VOLT OUT PUT FEED BACK FEEDS!
hummm  so if there really low volts? does that mean there much higher in amps ??????
