Joule Thief
0 Members and 165 Guests are viewing this topic.
jeanna
Quote from: freepow on December 30, 2009, 04:31:08 AM
@ All
Never though I'd ever light a fluoro with a small transistor, dont know wether it will burn out or not if I left it running for a long time...
I usually use the big trans - to light my flouro's, but thought I would try with this small one ! and it worked!
Nice work.
I think you are the first to do that!
Congratulations!!
@ist.
So, you stick the toroid wires under those colored screws?
Then you turn the pot.
I guess you connect the scope somewhere too?
This is a great idea.
Thank you for doing this and explaining it.
jeanna
edit...add
I am going to keep the broken transistors and recheck them in a month.
I have kept some neos stuck to a lamp for easy access.
I saw this morning that the metal case that holds the transistors (within another plastic case) has been touching that metal lamp which has the neos stuck onto it.
I am thinking if the magnetism of the neos hurt them, then it will relax given enough time.
That is what happened with the very first jt I ever made, which I mistakenly made on a ferrite magnet toroid.
It worked weakly then broke, but later the transistor seemed to self heal.
So, for experimental reasons, I will look again in a month.
J
tysb3
@ xee2,
@ kooler,
thanks, I'll join to this idea
xee2
Quote from: stprue on December 30, 2009, 10:20:02 AM
This was in the TPU thread!  Has anybody tested this JT variation?
http://video.google.co.uk/videoplay?docid=-1815461677597553845&ei=S6c6S_aPDs6z-AbGhuAc&q=tpu&hl=en&view=3#
Self running is probably a misnomer. It looks like it is running from a charged capacitor.
resonanceman
Quote from: gopalyajur on December 30, 2009, 12:12:46 PM
Hello Everyone,
Hope you all had great Christmas.
I have been following the thread for a pretty long time and did learn a lot from
everyone here. I was busy with my thesis for a while and did not have enough
time to build a HV Joule thief until recently. My Joule thief is putting little more than
1800 V A.C (i would say spikes) with the following configuration
2N3055 transistor
1.5 inch toroid
base winding - 4 turns
collector winding - 9 turns
3 layers of secondary - almost 500 turns with 26 # winding
1K pot to control the base current
with all this my CFL (11 watt) only shows a faint glow.
I dont have a camera now, will try to post some pics later.
And would check the scope readings when am back in the office.
In the meantime can someone let me know why I only have a faint glow
is it the frequency??
Anyways wishing you all a HAPPY AND A PROSPEROUS NEW YEAR!!!!
Gopal.
Gopal.
Welcome
Its always nice to have more  expermenters here.
How many JTs have you made?
It sounds to me like you think  kind of  like I do.
I made a couple  of JTs then went for the gold.
I started  putting  as many windings on the toroids as I  could.
They did not  work .
It appears that like most other things JTs  require a little moderation.
If I waS  you I would  try tuning the  secodary  by taking about a half dozen turns at a time off ....... Your  voltage may drop......but I think  with less turns .......... you will be able to light a floro brightly.
Just tune it slowly ....... the idea  is to find  the sweet spot .
gary
crowclaw
Hello Everyone,
2N3055 transistor
1.5 inch toroid
Gopal.
Hi Gopal,
CFL's can be tricky to light brightly and yes frequency can make some difference. It's purely a matter of trial and error and not allways more windings / more voltage will produce the results to ignite. You can try removing turns, also connect one winding of your secondary to the collector_the other to one end  of your CFL, while the remaining CFL connection to ground or back to the collector.
