Joule Thief
0 Members and 169 Guests are viewing this topic.
innovation_station
J you see the GAGA...  lol
to answer your question ...  put a cam flash cap ....  where i run my leds and my motor from ... allow it to charge to 120v or as high as you can ..THIS IS WHAT MK1 MEANS BY LOAD IT !
in doing so PROPERLY...  this will drive your device to run faster ...  i have demoed this in SIMPLE MEANS a long time ago ... via pulse motor
here is the video ... SAME THING .... NO MOVEING PARTS ...
take in the gaga show ...  and plug your cam cap and neon there ..
thank you !
w
loading  a pulse motor with a cap to cause ACCELERATION!   THEN LEAVE IT ALONE ....  pull from YOUR MUCH ACCELERATED SECONDARY!
http://www.youtube.com/user/innovationstation#p/u/15/SOSSn7UTWOU
jeanna
Quote from: Mk1 on January 03, 2010, 06:01:40 PM
This is about the circuit kooler and xee are working on , i can't find the schematic .
Mark
OIC
It is like the way you taught me to collect the charge in a cap so I could see how much I was making.
@ist,
I am afraid I never understood those things you described so long ago.
But, I did use the cap across the secondary with a bridge and 2 extra diodes which allowed me to know how many volts I was making before I bought the little scope.
thank you.
jeanna
innovation_station
well that really SUX J lol
as it is key!
lol
ist!
THIS IS WHY THERE SELF ACCELERATING MOTORS... THE MORE YOU TAKE AND SLOWLY USE THE FASTER IT WILL RUN  THAT IS CLEARLY VISABLE IN MY LAST REPOSTED OLD VIDEO ...
the thing was feeding back to source .... HENCE RECHARGEING ITS SELF AND RUNNING ON ITS SELF.... PLUS I RECHARGED A GEL AND THE DRIVEING BATTERY ....  AT THE SAME TIME FROM THE CAP... take 13 12 vdc bateries ...  chain them ... 12 in 1 string ...  use 1 for power ... and 12 get recharged at 150vdc ...  lol
silly nut!
and guess what ... when i hooked up the second battery ... MY MOTOR RPM INCREASED TO MATCH THE RECHARGE LOAD ...  THIS IS RECTIFIED DC ...
thank you !
watch it agin!
jeanna
Quote from: innovation_station on January 03, 2010, 06:27:16 PM
the thing was feeding back to source .... HENCE RECHARGEING ITS SELF AND RUNNING ON ITS SELF.... PLUS I RECHARGED A GEL AND THE DRIVEING BATTERY ....  AT THE SAME TIME FROM THE CAP... take 13 12 vdc bateries ...  chain them ... 12 in 1 string ...  use 1 for power ... and 12 get recharged at 120vdc ...  lol
watch it agin!
Thanks ist, I missed that video.
I have now made a bedini circuit, so I can follow the basic.
What this is showing, if I understand it, is that you have 2 connections to the + of the cap.
1- is feeding it from the bedini output.
2- is charging the + of the running battery and uses a diode to keep the direction right.
you also have the (-) of the cap going to the neg of the running battery.
If all that I repeated is correct,  have another question for you.
bedini says the output must first go through a capacitor in order to run a bedini circuit.
Is this how it is supposed to be?
I am getting the feeling you have added something very novel to the bedini circuit.?!
thanks,
jeanna
innovation_station
thanks J
no cap on in put .. on this jobbie ...  i can totally eliminate ALL BATTERIES ..WITH EASE .. and all motion
HOWEVER ...  NOW IM BUILDING SOME TOTALLY KOOL SHIFT! this is how it works
ok
i have the npn tuner i have build and fully demoed ...  what is possible by a most basic coil and i dont care the core air if you want ... none the less thos 2 units  will power a much LARGER PULSE MOTOR!!!
and so i have it ALREADY HALF BUILT!  ONLY I WILL ADD A 10LB .5" THICK X 7.75 " COPPER DISC HPG TO THE PULSE MOTOR .. AND YES YOU GUESSED IT IT WILL RUN FROM A AA
PEACE!
do i need to make it self accelerate too ?
W
lol some clown leaves me a comment your starting to catch up ....  lmfao   ill leave you in dust sir!  hahahaha....
here ya go some pics ...
