Joule Thief
0 Members and 152 Guests are viewing this topic.
innovation_station
my mkc and all my units wich are like bedini all have FEEDBACK...  for years now !
and are pictured all over this site ...
and have  GOOD LOOK AT MY 3 TURN MAGIC MAKER ...
SO WHAT EVER I NEED TO MAKE MONEY .. AND SO I WILL
what i guess i must ebay it ..... GOOD GOD IM ON THE LARGEST RESERCH SITE ON PLANET EARTH IN A BOX WITH A BOAT LOAD OF DIOZZIE NUTZ...
YOU CANT JUST GIVE THEM HIGH TECKNOLAGY  YOU GOT TO PUT THEM BACK IN KINDERGARDEN!
AND RE TEACH THEM ...
yawn ...
and then sooon as they learn ...  way the dozzies go ...  or the WILLIS  story ...  know it too well!
w
THE SUN IS ON DECK!  BROKE  AS BROKE CAN BE ...   BUT I GOT MY WORK ...
IM MAKEING DIODE MOD BOARDS FOR THE MAGIC MAKER !
WHO BUYS THINGS ?  THIS DIODE BOARD will plugg into the magic maker and give 5 feeds ... ontop of eather jt pulse coil flyback ... like i have demoed many days now ....  or the secondary ...  of the coil   if i tap base and not pulse ...  then i can use the ou put of the secondary/s ..
no sence applying for the OU PRIZE IT IS A HOAX!
THE ONES THAT CONDUCT THE CONTEST ...  ARE THE ONES THAT DONT HAVE THE CORRECT ANSWERS!  stands to reason ... lol  or why the contest at all?
agin you give them the TRUTH  and they argue till there blue in the face and leave ! but yet ... do not disprove my work ...
seems like a carrot for the nutz the fell from the stupid tree!
why the big ram on for something iIi SOLVED YEARS AGO ... ?
??  CANT FIGURE IT OUT ?   i gots my work .. AND AINT NOT 1 GONNA TAKE IT!
HERE IS A LINK FOR THE CLOWN! /S LOL
DUH!   LOL  DUH!   HUMMMMMM!
http://www.overunity.com/index.php?topic=3852.0
Temple of Horus Description
The 2,000 year old Temple of Horus, almost perfectly preserved, creates an overwhelming impression. Built on the site of an earlier temple, it was dedicated to the sun god Horus, Hathor of Dendera and their son the youthful Harsomtus (Hersemtawi), "Uniter of the Two Lands". The history of its construction and a description of the whole structure are set forth in long inscriptions on the outside of the enclosure wall, particularly at the north end of the east and west sides. The rear part of the complex, the temple proper, was begun in 237 B.C., in the reign of Ptolemy II Euergetes I and completed in 212 under his successor, Philopator. The decoration of the walls with reliefs and inscriptions, interrupted during the troubled reign of
... More >
Epiphanes, was resumed by 176 by Philometor and finished in 147, during the reign of Euergetes II i.e. exactly 90 years after the laying of the foundation stone. Euergetes II also added the large vestibule (completed in 122) and decorated it with reliefs. During the reigns of Ptolemy IX Soter II and Ptolemy X Alexander I the forecourt with its colonnades, the enclosure walls and the pylon were built, but the pylon was decorated with reliefs only in the reign of Ptolemy XII Neos Dionysos. The building was finally completed in 57 B.C. The building material was sandstone. Some of the relief decoration was defaced in Christian times.
The temple was surrounded by a high brick wall, part of which survives. The main gateway was on the S, in the central axis of the temple, and there was a smaller gateway to the W.
jadaro2600
Quote from: Pirate88179 on January 03, 2010, 10:19:15 PM
Jeanna:
You may be onto finding one of the keys to a self-runner there.  Start it with the battery, and then...maybe you don't need one?
Hey, you never know.
Maybe putting a capacitor in parallel with the battery in the first place will allow a charge to remain 'in the tank'...  removing the battery will ??? ...and then, some signs will appear.
resonanceman
Quote from: Mk1 on January 04, 2010, 02:06:46 AM
I mean your regular circuit but with a flyback jt on the first stage , the cap will fill faster.
I have seen that coil before
in case  somone  wants to make  a similar coil that one  is made  with 3 spools  of wire from Radio Shack  2 spools of green ( 75 ft # 26 )  and one  spool of gold ( 40 ft #22 )
After  removing  the core from the flyback  transformer I made a tube from  a piece of plastic  and tape to cover the  round part of the core.
I then took one end of the core off and wound the 3 spools of wire around the   plastic  tube .......using the other half  of the core as a handle.
When I got to the end of the #22 wire I just bent the end out of the way and let it hang ........I just kept wrapping the other 2 wires untill they were  all on the tube.
I then put  the core back together and  put some  electrical tape over the windings ........and added the primaries
The primary is MK2
It is shown  with 3 windings on each  leg
I later reduced  the white wire that goes to transistor base to one wrap each side.
I never  tried putting  the 2  #26 windings in series I always used them  in parallel .....it had enough voltage for me.
The  2 #26 wires  in parallel put out around  450 V with one AA battery .......enough to light a 25  W CFL to about half brightness.
The #22 winding  put out around 200 V .......enough to light my 90 LED array very brightly.
I was able to  use some inductors  to balance the load and run both the CFL and the array  at the same time........but one of them was always  dim ......it didn't have the power to run both at once at full brightness.
I tried   hooking   an ignition  coil  up in series  with the  the green  wires .......( to add flyback )   I fried a 60 LED array and a DMM
gary
resonanceman
Quote from: innovation_station on January 04, 2010, 09:07:11 AM
yawn ...
w
Silly Spaceman
I just thought  I would set the record straight.
You have made  alot of really impressive stuff ............but  that does not mean  you have given us  anything.
You forget  that most of us  do not have your experience  or intuition about these things .........so yes you have to explain things as if you are talking to children
You seem to talk  mostly in your own code.
You know  exactly what  you mean........ but most of the rest of  us are lost ............ tic tic boom
I can only remember 1 schematic from you ........ I think it was  for making a PWM from a 555
I would  love to know more about how  some of your circuits work........but I gave up asking about them long ago............because your answers are in code or sharthand .....they make no sense to me.
I do  berlieve that everyone  has potential for genius inside of them
I think  you have found that potential. ........
Just  because  understnding  and building these kinds of circuits comes easy  and  natural for you  that does not mean  that it is easy or natural for the rest of us.
You might  think about  not calling us  silly humans any morec........ why not  try normal humans    :)
Don't get me  wrong here.......I am not saying you are any smarter  than  anyone else here .......this is just your element more than it is ours  .......please keep that in mind.
I am like you ........ I am a genius in some ways........but I am also very dumb in many ways . The dumb  is what most people tend to see first.
You could be  of great help to the people here ......but so far you have been very little help
To  be  if great help  you WILL have to talk to  us like we are dumb .......without treating us like we are dumb
I need all the help  I can  get ....  I need the procress walked through step by step ........I need schematics
Once I can see it in my mind........then I got it ......  My mind is mostly  visual.
One of the ways I am a genius ........I am a peacemaker ........can you feel the peace?
gary
jeanna
Quote from: jadaro2600 on January 04, 2010, 01:08:00 PM
Hi jadaro,
I will try that today.
Thank you,
jeanna
Quote from Gary
QuoteTo  be  if great help  you WILL have to talk to  us like we are dumb .......without treating us like we are dumb
I need all the help  I can  get ....  I need the process walked through step by step ........I need schematics
That is beautifully stated Gary.
Thank you.
I agree, IST.
You have a lot you could share and in the last few days you have begun to make many of your ideas more clear, and you may continue to make them EVEN MORE clear.
Schematics or drawings like the ones that kooler or slayer make are fine... possibly even better for most people to follow.
thank you,
jeanna
