Joule Thief
jeanna
Quote from: Mk1 on January 11, 2010, 07:40:26 AM
.... i am working on a third one , this time exactly like agentgates,
well i think at 45 degrees , 2x18 , ...
..., those are the picture of the new one , i get 35 volts on a 6 turn secondary , so its getting better and better .
I would never have believed it , all that without toroid , and yes its a air core but it works at the same freq a regular jt does .
Hi Mark,
I have a freshly emptied roll to try this now.
Is this reall a toilet paper tube?
It looks bigger in your pic.
I will begin anyway, since I am ready.. ;D
jeanna
Mk1
@jeanna
Yep it is a toilet paper roll , one big one , the type you find in schools and garage industrial type 3 7/8 (diameter) by 3 1/2.
It seems that the best angle is 45 degrees but i was thinking 15/75 degree .
both work , it also seems the more turn on the jt side gives more output.
And seems to work better with the jt wires with a space between the wire .
Mark
gadgetmall
Quote from: jeanna on January 12, 2010, 06:31:01 PM
Good,
Now, would someone please explain if it is OK (not too dangerous) to put a cap somewhere and a resistor and get some warmth out of the end??
How much,  and parallel or series?
I burned 5 fingertips after I tried to charge my bcap from touching the 12v leads . I am sure gadget forgot to mention the resistor, but I need to know all the details because I am new to things like this.
Can you explain it, xee2?
or someone??
jeanna
jeanna i did mention that it smoked My 12 volt power supply and burnt teh wires off it . It will Smoke  em and get a regular battery charger HOT. I just got a new Vector smart charger  80 amp  . It charges it perfectly with no heat at all in about 10 seconds . I use a Peltier Modules to get long term heat or cold . We are trying to devize an insulated  canister to contain the heat in oil therefor producing a continuous heat source in between Charging with the JT ,sort of like a radiator . I will make a video shortly of 6 bcaps in series running a 110 inverter powering a Tv or something from charging with Jts . . Of coarse we need a better faster cap charger but the potential is there to run stuff after they are charged .
Albert
Mk1
Quote from: gadgetmall on January 12, 2010, 06:54:07 PM
Albert
Make a cap charger TV ... :D
innovation_station
i can fully explain koolers unit .. and xee2 's
how and y
but i have done lots already .......
Q   all you need to do is load it !!
if i put my 350 v cap ...  to load it ... I WILL BLOW MY SUPERS!!  ; )
w
y i have used 35v 17000uf to load it ....    and it is not large enough it still over charges my  supers ...
with my design ...  i can use 1 b cap as input ... 6 as out ...  and same thing .... i will blow them if i dont use it fast enough....
MY NEXT STUNT IS TO LOAD IT DOWN WITH BATTERIES AFTER THE CAPS
thank you ...
so it dont blow up .....
this is why i pulled out 6 of em   and THEY AINT SMALL BATTERIES ....   NOT AT ALL!
SOLAR DEEP CYCLES!  2 OF EM 12VDC !
ALSO I WILL CLOSE THE LOOP  ...  I HAVE IN MY WORK SHOP ALL THAT IS NEEDED FOR FLAWLESS RUN !
PEACE!
i have seen my first load cap go over 26vdc ...  there is where the deeps will go ...
other load cap hit 15vdc ... tractor there....   gel gets stepped down ....  to self run via adaptor ...
