Joule Thief
0 Members and 122 Guests are viewing this topic.
kooler
ist
draw me something.. i like stick people too..
@all
something to try..
innovation_station
i have something else i can employ for the TINY 404 ... LOL
it is a flasher cap full driver ... to a 12vdc flasher work light ...
basically  what happins in this device in this method showen ..
is this i fire up the wobbler 404 and i use the rectified out in a cap to push to a 12vdc cap full flasher .. it dumps to the 12 v strobe ... it fires a mot ... careful.....
be 4 warned!   it is a blast ... i have all laying round ....
PERHAPS I SET UP TABLE #4 AND DRAGG IN SOME MORE ROUND TABLES ....
ist!
i can most likely fit 8 more round tables in here .....
can i juggle all things at once ?   yikes  ...   i have a well proven track record !
jeanna
Quote from: kooler on January 17, 2010, 07:26:28 PM
@all
something to try..
Kooler,
Is this the one that is reverse charging the battery?
thank you,
jeanna
kooler
jeanna
it does seem to charge..
i pulled one battery off 3 hours ago.. and the volts are still up and i put a small load on it and the volts only fall about 0.021 and come right back up as soon as i pull the load off
so i put another battery on this thing and checking it now to see if it will recharge it
.. it seems to go alot faster once i pull out the led.. of course
i just playing right now..
but making it this way does help lite the led brighter
jeanna
So, what happens with a 7-10 turn secondary?
A secondary frequently has nothing to do with the amps draw from the battery, and often lowers it.
The problem is sometimes it puts out a light that is in the place of your light, and if it does this, then reverse it if possible.
If you can find the direction for a secondary light that does not turn off the primary light, then you can probably remove the primary light and the battery might recharge...(and you will still have a light, and with more turns it will be full bright.)
This makes me wonder, if the C-E is interrupted by a battery, will the battery recharge?
I think this is what gadget was doing, but he said a battery wouldn't recharge enough. hmm
jeanna
