Joule Thief
0 Members and 99 Guests are viewing this topic.
Mk1
@xee
thanks That is what i tough , i was surprised when my last coil did not lower the pulse.
xee2
@ Mk1
Quote from: Mk1 on January 17, 2010, 11:26:18 PM
@all
Could anyone tell me what happens to the jt regular output when you put a resistor load on it , or even close the secondary (closed circuit) , Would the voltage go down between the collector and battery negative rail , or stay the same or up.
Anyone.
Try it. I think shorting secondary will reduce collector pulse voltage.
xee2
@ Mk1
Quote from: Mk1 on January 17, 2010, 11:42:18 PM
I am confused because on my tp unit , i can't shot circuit the secondary , and the jt side is still fine , put i make 2 secondary one on a white led (2 turns)
And a red led (4 turns) , both light , and the collector and negative rail doesn't even flinch.
Well, 2 turns and 4 turns are not much inductance. How many turns are on the collector coil? Usually the pickup coil has a lot more turns than the collector coil.
Mk1
Quote from: xee2 on January 18, 2010, 01:28:59 AM
@ Mk1
Ok What i did is make a bigger one 22 turns 18 gauge , and closed the secondary got 33 volt pulses for 39 volts open. It dose lower it a bit.
Collector 36 turns 24 gauge.
xee2
@ Mk1
As I recall, all of the open pickup coils do not absorb any energy. But any pickup coil that has a load will take energy away from the other coils.
