Joule Thief
0 Members and 114 Guests are viewing this topic.
Mk1
@all
It was a demonstration of my new tool , to analyze the performance of my new coil, and there are no other way i could think of .
Now my new coil doesn't seem to show really high voltage , but it has more power then any coils i have made before.
The output from the secondary are almost independent from the jt circuit , it helps when you have many secondary , even the pickup coil is loaded the jt runs unaffected.
It runs motor 12 dc no cap , filament bulb , not the regular jt .
I did see your experiment with the cone, 2 turn secondary plus asymmetric pancake coil .
Now for the Cardboard tube , you need 2 coils going around the core like a regular toroid, but the coil needs to be at 45 degree on both face of the core , those are the base and collector coil the one on the outer rim is the pickup coil.
This is a basic version , you are supposed to leave room between the wires ,
Also when i say many time around (revolution ) , You understand , A bit like the Rodin coil .
The secondary works with bigger wire , bigger the better , More turns on the base and collector coil means more out of the pickup coil.
Mark
xee2
@ Mk1
Quote from: Mk1 on January 23, 2010, 01:38:03 AM
my new coil
That is an amazing coil. Will this version light a filament bulb using the pickup coil?
Mk1
Quote from: xee2 on January 23, 2010, 01:49:49 AM
@ Mk1
Yes , i am already on a new one , i will try to make it better , they all light filament bulb , to different degree , but there is so much more to it...
I will try to make one from a smaller tube , commonly found around the house and take all the pictures needed to make some follow along instructions.For those that really need it , but honestly it is so new , better design will come along , lets let it evolve like the jt usually dose .
But this is like step one , and it feels like going backward , but there is more then just volts .
Thank for your interest.
Mark
jeanna
That is good so far Mark,
Now, how are these 1 and 2 to be connected?
Are they eventually connected to each other in series?
Are they connected end of 1 to beginning of the other?
The secondary is easy,
It is the primary that nobody has managed to get through my head! ;D
@All,
I just posted something which I believe will help many who live in countries where they cannot buy the toroids we have.
I just took the little orange toroid from a small cfl and made a very powerful joule thief whose secondary is 60v at 62Khz.
This will light 8 leds blazing bright (as I showed) and with 10 strings of leds connected in parallel the amount of light will fill a room with no more amps draw from the battery than one led.
I wrote the recipe.
I am very pleased to have been able to do this.
I hope it can help many people light their homes.
jeanna
xee2
@ Mk1
Quote from: Mk1 link=topic=6123.msg224498#msg224498 A=1264230249
Great. I think a photo of just the base coil on the tube would help people understand better how it is made.
