Joule Thief
0 Members and 57 Guests are viewing this topic.
innovation_station
the b cap charges ok ...
i have choosen to not share results any more regarding the crap cap ...
lol
make it better your self ...  lol
MY DEVICES WILL NOT REQUIRE SUCH GARBAGE...
and just cuz i can fill them faster ...  than  most ...
o well
and i have it all public ...  there for it shall never be taken from my hands...
and im a sue if i find things on the market useing my teck!
thank you !
william
you dont need to look far to see the reach of my HANDS ...
simply ask richard willis...  : )
lets just say i made a simple coil ...  with simple wire ... i can not use a 2n2222a on it as the instant i turn it on .. i blow em up...
clearly cuz the fly back is toooo much for the little cridders ...
crowclaw
Quote from: zhak on January 24, 2010, 06:56:00 AM
Earth Battery
Hello friends, I have long hrnitsya archive this scheme, but there's no time to understand, give it to you. If sobiret, then wait for the results!
link : http://www.patlah.ru/etm/etm-24/a_energia/avtonom_energia/avtonom_energia.htm
Hi zhak,
This is an interesting circuit. It's basically an antenna fed tuned circuit coupled to a booster circuit. Have you any idea of the outputs claimed? Kind regards
jeanna
Hi everybody,
I have just received an email from the first distributor of large toroids I contacted (MTL).
They say they never quoted me a price on the large one since they never had it.
They have the 2 1/2 inch one which I recently used.
It is excellent but not strong enough... maybe for the big cfl.
The one they have is epoxy coated and costs 12.40 so, in a way the 25 dollar minimum is easily met however the quote is for 3, so it is really around $36.
This is a retail sale and they have them in stock.
So if you can get over the price surprise, I do recommend this.
".....Concerning the cost and availability of OW-46113-TC (uncoated core), we do
not stock this core either, but we do carry ZW-46113-TC (and we will have
this core on Feb 05,2010).  If you require the uncoated version, Dexter
Magnetics does have this core in stock. If you are able to use the coated
version, your price is as follows:
Part # ZW-46113-TC
   3-24 :    12.4000
  25-49 :     9.8700 "
I apologize for all this, and I hope this can help those who seriously want to make some with this.
jeanna
PS they also said the following:
"With regards to OW48613TC, this is not a core that we normally stock. It is
available directly from the factory (but there is a high minimum order).
This core is also available from Dexter Magnetics or Allstar Magnetics (they
are Magnetics other distributors).
With regards to the price, this core is a very large (and expensive) core
and it is unlikely that it will be available for the $2 range as the factory
distributor price is well above this range. If you only require a few pcs to
test your design, you may be able to request samples from the factory."
jeanna
Quote from: zhak on January 24, 2010, 07:03:49 AM
jeanna !
In this video, connecting 19 LEDS Joule Thief Lamp Modified resistors you DO NOT USE?
http://www.youtube.com/watch?v=Hc2B2rzthoA&feature=channel
Hi zhak,
I am trying to show people how easy it is to get usable light from a joule thief.
In that video, I have modified a light that has 19 leds so that all that remains is the 19 light bulbs.
So, yes, in that case, I removed the resistors, capacitors, and fuse from that light.
Doing this allows me to use a smaller toroid and transistor for the joule thief.
Are you able to get that "Lights of America" light bulb?
I have made other joule thief circuits for this same LoA bulb UNmodified, but when this bulb is unmodified, it works better with over 300 spikey volts, and that requires a different transistor [TIP31 or TIP3055] and possibly a bigger toroid.
thank you,
jeanna
google translator
made 2 translations, I think?:
ПривеÑ, Жак,
Я пыÑ,аюсь показаÑ,ÑŒ людям, как легко можно получиÑ,ÑŒ использоваÑ,ься свеÑ, оÑ, джоуль вора.
Ð' эÑ,ом видео, я изменил свеÑ,, коÑ,орый имееÑ, 19 свеÑ,одиодов, чÑ,обы все, чÑ,о осÑ,аеÑ,ся 19 лампочек.
Так чÑ,о, да, в Ñ,аком случае, я удалил резисÑ,оры, конденсаÑ,оры, предоÑ...раниÑ,ели, и с Ñ,ого свеÑ,а.
ЭÑ,ом позволяеÑ, мне использоваÑ,ÑŒ меньшие Ñ,ороида и Ñ,ранзисÑ,оров на джоуль вора.
МожеÑ,е ли вы получиÑ,е, чÑ,о "Огни Америки" лампочку?
Я сделал другой джоуль сÑ...емы вора за эÑ,оÑ, же лампа Одобрения неизмененной, но при неизмененныÑ... эÑ,а лампочка, она лучше рабоÑ,аеÑ, с более чем 300 Spikey вольÑ,, а эÑ,о Ñ,ребуеÑ, другого Ñ,ранзисÑ,ора [TIP31 или TIP3055] и, возможно, больший Ñ,ороид.
Спасибо,
Ð"жинн
Privet Zhak,
YA pytayusʹ pokazatʹ lyudyam, kak legko mozhno poluchitʹ ispolʹzovatʹsya svet ot dzhoulʹ vora.
V etom vidyeo, ya izmenil svet, kotoryĭ imyeet 19 svetodiodov, chtoby vse, chto ostaet·sya 19 lampochek.
Tak chto, da, v takom sluchae, ya udalil rezistory, kondensatory, predohraniteli, i s togo sveta.
Etom pozvolyaet mne ispolʹzovatʹ menʹshie toroida i tra·ezistorov na dzhoulʹ vora.
Mozhete li vy poluchite, chto "Ogni Ameriki" lampochku?
YA sdelal drugoĭ dzhoulʹ shemy vora za etot zhe lampa Odobreniya nyeizmenennoĭ, no pri nyeizmenennyh eta lampochka, ona luchshe rabotaet s bolyee chem 300 Spikey volʹt, a eto trebuet drugogo tra·ezistora [TIP31 ili TIP3055] i, vozmozhno, bolʹshiĭ toroid.
Spasibo,
jeanna
innovation_station
LIKE I SAID I WILL NO LONGER CONDUCT BUISNESS US SIDE ... THANK YOU
YOU CAN THANK GADGET ..
REGARDS!
I NEED NO BIG  CORE ...
THANK YOU !
2 questions b4 i post my next video ..
xee#2   i will ask you first!
why the large plastic coated wires?
j  do you use coated wires ...  : )
of course i have the correct answer!
regards!
share if you care ...
W
http://www.youtube.com/watch?v=FobNbMuoGbQ
thanks robbie!
aint nuttin like the REAL THING !   : ) BABY...
LITTLE BOY BLUE AND NO MORE MAN ON THE MOON!
NEW MOON ..
WELCOME K ; )
NUTTIN LIKE KICKING THE BOY WHEN HE IS DOWN ...  A GADGET !
NUTTING LIKE THE BOY GROWING UP TO A GIANT ...  AND STEPPING ON YA !
