Joule Thief
0 Members and 46 Guests are viewing this topic.
Mk1
Quote from: xee2 on January 25, 2010, 03:09:33 AM
@ Mk1
Like this?
@ xee
Yep , Just mark the numbers of turn you need , make a 45 degree angle to determine the length of the tube.
The last one was a 36 degree spacing , and 45 degree angle .
Most of the prior ones i have made only made 3 turns per revolution (astronomical definition) the result got i bit random .
I like my new technique , make a 45 degree stencil in paper , chose your spacing , take stencil make 45 degree mark , cut where the 45 and the next division meet.
Mark
xee2
@ Mk1
Then I assume the base and collector coils are like this. Are they close together as in this drawing or spaced far apart?
Mk1
Quote from: xee2 on January 25, 2010, 03:41:46 AM
@ Mk1
You got it , you are supposed to leave room between the wires .
The first coil i have made , most of the wires i got are too short , reason for the bigger gap.
The last one i have posted , did not have enough space , but i will test it anyway , we will never know otherwise.
The one i have posted lighting a filament bulb was like that , the 2 coil parallel to each other (like your drawing) .
This one one wire going one way the other 45 degree the other way making a x in the middle. this will be my second unit built like that.
I also edited my last post , with picture.
Mark
xee2
@ Mk1
Half way between like this?
Mk1
@xee
More like this , this is type 2 .
