Joule Thief
0 Members and 45 Guests are viewing this topic.
jadaro2600
Quote from: xee2 on February 12, 2010, 11:10:24 PM
@ jadaro2600
Are you using air core coils? It may not be the magnets, it may just be that you are bringing something magnetic into the field of the coils - plain steel may do the same thing.
These are prefab inductors with ferromagnetic cores.
I've attempted to setup a few other tests but they've failed, I think I fried my transistor in the process, oh well, ..12 cents of equipment. :P
Anyway, I'll try some other adjustments, The idea is to use only a single inductor - which can be done with two transistors, as has been seen elsewhere.  I'm trying to fit the entire circuit down to the size of a flashlight bulb, using that setup, I can create a flashlight of longer battery life, or fewer batteries.
sparks
  Intersting series circuit dont ya think.  I cant figure out which battery is discharging and which one is charging.
Think 3jt running out of phase
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Mk1
@jadaro
I lets both bulb run for 60 min and there is no heat on either the on on the secondary or on the transistor.
Mark
jeanna
Mark,
The coil on the video looks like the one that has a lot of spaces on the primary. Then I see the whole width being a single layer secondary of thick wire.
Is this right?
jeanna
Mk1
Quote from: jeanna on February 13, 2010, 12:23:56 AM
Mark,
Is this right?
jeanna
That sounds right .
I will re-post the picture .
http://www.youtube.com/watch?v=wS935WyumjY
On the video i try to put as much visual info as possible but my camera is so crappy .  And this is the same one i posted a while back.
I am planing a new video if my battery allows it , they don't seem to hold the charge anymore. This time running a motor .
Mark
