Joule Thief
0 Members and 96 Guests are viewing this topic.
slayer007
Quote from: stprue on February 15, 2010, 03:49:17 PM
@ Slayer
How do you A your large coil?
Here is the circuit I have been using.
Notice there is a diode going from the negative side of the capacitor to the positive side of the source battery.
The capacitor has a very big field around it also.So I was just trying to send that back to the source battery also.
I'm still trying differant coils setup and a pancake coil for L2 also works very well.
When collecting the BEMF from L2 coil the light is brighter.
And also when there is a bigger load on L1 the BEMF increases.
stprue
A no wonder I was getting poor results!  I was missing a coil and trying to get it to work using the simple SEC set up with a trigger coil!
Thanks for the clarity slayer.
P.S. Did you seesome of my pics a page back?
slayer007
Quote from: stprue on February 15, 2010, 05:43:42 PM
A no wonder I was getting poor results!  I was missing a A and trying to get it to work using the simple SEC set up with a trigger coil!
P.S. Did you seesome of my A a page back?
Stprue very nice job with Jonnydarvo's simple SEC.
P.S. Dont forget to do a tap start to start it.
Just connect the resistor to the base then disconnect it.
jadaro2600
I soldered some leads onto this :: http://www.goldmine-elec-products.com/prodinfo.asp?number=G2859 :: Toko coil from goldmine electric and setup a standard joule theif circuit with it.  It has 6 leads, two coils, center tapped.
I haven't been getting great results from it - it's stats are essentially unknown, but it does act as a transformer.
I did notice however, when I employ this setup, I can increase the over-all DC voltage gain from the coil.
PS, Upper inductor has more winding than the lower inductor.
edit: diagram was off a bit.
xee2
@ jadaro2600
Quote from: jadaro2600 link=topic=6123.msg228505#msg228505 A=1266278683
I soldered some A onto this :: http://www.goldmine-elec-products.com/prodinfo.asp?number=G2859 :: Toko coil from goldmine electric and setup a standard joule theif circuit with it.  It has 6 leads, two coils, center tapped.
What happenes if you remove the center tap connection and the two capacitors from the upper coil? I would think this would be a standard JT with a pickup coil then. Does your circuit work better than a standard JT?
