Joule Thief
0 Members and 116 Guests are viewing this topic.
jadaro2600
Quote from: Mk1 on February 17, 2010, 02:10:38 PM
@all
You got to see this !!!
http://www.youtube.com/watch?v=8G3MrxueODM&feature=player_embedded
Mark
Cools, looks like bloch-wall micro-variations causing plane shifting in the pickup.  Be nice to get a better diagram.
slayer007
Quote from: altrez on February 17, 2010, 02:16:08 PM
Nice work slayer007! I have been charging batterys with my Joule Thief but it will only charge 1 at a time. i can run A and a small motor at the same time as well.
Have you did any tests to see if your charged battery's are experiencing empty voltage? I know my battery's will charge to a full 1.33 volts but not last as long as if I used my wall charger but yet they get the same voltage.
Keep up the great work!
-Altrez
Yes and No lol.
There was two bad batteries in with the 10 that will not hold a charge.But there over 3 years old and they don't hold a good charge with a conventional charger.
So they were replaced with newer rechargeable batteries today.
I also bought 2 small 6v sla batteries today.I would like to run it off a 6v battery and charge the other two batteries while running the led's.
you can find the circuit for this a couple pages back.
xee2
@ Mk1
Mark
Thanks. Excellent demonstration. I am not sure what is happening, but the magnet deffinitely helps.
Mk1
Quote from: xee2 on February 17, 2010, 02:39:51 PM
@ Mk1
Thanks. Excellent demonstration. I am not sure what is happening, but the magnet definitely helps.
It seems to work like the orbo , and the solid state version , to some extent the MEG , i think the basically the theory suggest that the toroid and its coil disrupt the magnetic form the magnet , so the pickup coil is under stress from the magnet at all time except when the toroid is triggered , so the change in the magnetic strength induces voltage in the pickup coil .
I hope my explanation helps .
Mark
stprue
Quote from: altrez on February 17, 2010, 02:05:46 PM
Wow that's cool. I don't have any small diodes like you are using will 1n1004s or something similar work? I have been using 9 volts on the CFL driver is 5 volts recommended?
Thank you so much for the help!
-Altrez
Mine says 5 v's so thats what I put in but you can put in a little more or less!
