Joule Thief
0 Members and 28 Guests are viewing this topic.
innovation_station
a freq genny alone can do it ..
i used the mags genny on a coil in the past on the .1v setting and i was able to mesure 70v out .. of a tesla tpu coil ...
W
i just tryed the ALI 4" on a large value cap .. it charges it well
cap 50vdc 20 000 uf .. likes to hang out round 20vdc in that cap .. useing a 1.2vdc source .. and the 2n2222a
the cordless drill battery sat all night it has 12.77 vdc in it ..
i used a 35 vdc 17000 uf cap it charges it well too .. 22vdc and climbing ..
now i did notice while chargeing and playing with the cam units .
and be carefull!!!!!!!!   ok
i did not realize the cam cap had some juice in it .. i connected it to the big a$$ cap .. and HOLY SMOKES SPARKS ...
wow i had to take a 15 min break after that to see if i was brave enough to do it agin ... it litterly scared me ..
after the heart skipped a beat i hooked it up agin ...   lets just say ..  i was useing a cam cap it had a few hundred volts in it .. it discharged to an empty cap of many uf same voltage ..
what happened next was nothing short of amazing ...  after the big spark show i ended up with 14 vdc in my large cap ...  from 1 bang ......................................
hummmmmm
as i said be damm carefull if you play with this ...  400v at 2500 uf  could seriously  lift ya !
so the big cap i have is  2500 uf 400vdc ...  not 20 000
now if we could get CHUCK BACK HERE .... lol
we could then go YOUNG EFFECT! : )
innovation_station
dont mind i steal the MIC!
lol
i can use a cam unit  or a ali coil   to fill the first cap i could then PASS THE PUCK... : )
meaning bridge rectify off first cap ...  put it to a switch to a coil to a second cap ... throw in a diode ..  catch the colpase of the cap discharge from the first coil ...
i have some simple controllers .. that could control this  4 channel 5 channel 3 channel  how many channel you want ...
lol
if my coils drove a pulse motor too it could get to flying fast ... : )
this unit runs with gain ... it is self explanitory ..
ist!
the work performed by the motor is free ...  and i will end up with more engery in my caps than i started with ..
AND IT RUNS ON A SINGLE AA...
coils or bulbs or both ...  lol   why not both free light is good  free work is good .. free engery is great!
an aa means it will run from solar or EB
: p
come on now who is going to top it ...
altrez
Quote from: innovation_station on March 16, 2010, 03:41:57 PM
lol
lol
ist!
: p
Let me get a mic check..
I have successfully got my bucking Joule thief catching the field collapse in reverse and energy amplification with fast enough switching. Lets see 1 AA to prime the caps then you can pull the AA.
Its really easy you can also run battery charging circuits to the caps that are powering the Joule thief. It works great. Oh and I am pulling power at 90 degrees to each Joule thief all one the same big toroid!
Full docs and schematics coming soon =)
Much Love,
-Altrez
jeanna
Hi Altrez,
Full docs and schematics will be very helpful.
Thank you,
jeanna
Oh, what does it mean to pull power at 90 degrees?
altrez
Quote from: jeanna on March 16, 2010, 04:54:48 PM
Hi Altrez,
Thank you,
jeanna
Hey jeanna!
First let me say good job on your camper lighting. that was a really good pic.
So let me explain how my idea works with the bucking effect. You have one toroid for example your biggo. You add two Joule Thief circuits at 180 degrees to each other. You then add for pickup coils each at 90 degrees.
on the pickup coils that are 90 degrees to each other you add a collection cap with a blocking diode 1n1004. This keeps the collected charge in the cap.
On the other two pickup coils you run them back to the battery of cap that is powering the Joule thief circuit. with a blocking diode on them as well.
This will charge the battery for the the Joule Thief across from the one running.
There are lots of issues to be worked out. But the basics are you are charging the source battery and collecting extra energy in the collector caps. It works and is super easy to replicate.
However the real bucking energy effect happens in a mico second. Thats where the switching comes into play. If you time it right you get a buck in the fields causing energy amplification..
Take Care,
-Altrez
