Joule Thief
jeanna
Well, what I did has no real bearing here. It is all pulsed, not steady dc.
I made hundreds of posts.
The easiest way to show what "I" did is to watch the lidmotor videos he called jeanna's light.
http://www.youtube.com/profile?user=Lidmotor#p/u/37/KAakZTR_4LE
That is the first.
He made a correction in the second so it is good to watch both.
Then I made a replication of his...
http://www.youtube.com/user/jeannacav#p/a/u/6/dTyprZxxza0
That is a good start.
jeanna
innovation_station
Quote from: sparks on March 26, 2010, 11:08:58 PM
@detrix
    If you change your motor to run on high frequency it may be easier than making a jule thief which produces real highfrequency from low current.  A high frequency motor is what they use on aircraft because they are smaller faster lighter and pack a bigger punch per pound.  They operate at about 40ohz.  A pulse motor can operate at thousands of hzs.  The steel core is what holds you back.  Some day not too far in the future there will be ceramic motors of 100s of horsepower that way 30pounds.  The magnetic bearing and hightech ceramics is making this doable.  The pulse motor links usually to a flywheel that changes the hf pulses to a more usable form of power.
sparks i agree and diss agree!
ill leave it there .. : )  kool!  lol
J  you  should try your coil on a ferroite transformer core ....
there every where ..
and your work does apply ... lol   add a bridge .. a high freq one if you have a high freq coil ..  i call high freq mhz at leist !
i have many mhz coils ..  next cap the damm thing .. now its dc ..  the funny thing is
in the cam boards look how and where the diode is placed .. they put out pure dc .... ; )
how can i say this ..  when my lite winds down .. as in the cap draing my leds are not pulsed .. the device is turned off my leds lite 5 plus min... after being switched off ..
clearly it is not pulsed ac dc or other output ...
as it is shut off !
w
the cam board is resonant transformer on on cycle and free electron snatcher on off cycle ...  lol
jeanna
Quote from: innovation_station on March 26, 2010, 11:28:04 PM
OK,
I see.
But the trouble is the time.
If the motor cannot be made to work at high frequency of pulses even from a cap it isn't going to work, but I am way over my head on this.
I have not made a newman motor and right now I am waiting for a kit so I can put together a reed switch motor.
Maybe in another year I can add something to this that is useful.
Maybe. anyway...
thank you,
jeanna
jadaro2600
just to note, i've gotten a couple of axial lead inductors used as the 'transformer'; they become inductively coupled and run very efficiently ..producing around 45 volts, oscillating at about 5Mhz.
innovation_station
if you want useable free high voltage that can do useable work ...
i found this to be the simplest solution ..
2 time for 100 times now ...
this means  verry high speed spike generator aka jt ...  and a a holding cell / translating device caps are best suited for this .. however batteries work aswell ..
now draw from storage in a slower time frame be it 1 hz or 100 000 hz ...  it dont matter SHIT... if your generator is 10 mhz ... does it ? and if your holding / pressure tank is large enough you can grab as much as you wish per dump ...
no it dont ...
SIMPLY ALLOW BUFFER TIME WHEN FIRST ENERGIZED ....  then engage phase 2 .. ie newman bedini ... etc!
W
in a car with a STANDARD TRANSMITION .. we call it a clutch ...  and we engage it and dissengage it for shifting gears starting and stopping ...
