Joule Thief
0 Members and 40 Guests are viewing this topic.
Pirate88179
Here should be 2 photos of my 2nd joule thief.  I packaged this one in an empty film (35mm) container and am running it off a single AA bat. in a battery holder.  This is placed face down into an empty water bottle filled with clear glass marbles and then filled with water.  It is bright enough to make a great night lite so you can see to walk to the bathroom, or whatever.  You can even read by it if you are close enough. (very close)  I also used a 10mm 28,500 mcd superbright LED on this one. (clear)  I bought some small switches and I will add one later.  This is a fun project.
Bill          *Edit*  I have found if you place it on a small mirror, it bounces light all over the room. *Edit*
WilbyInebriated
Quote from: maw2432 on December 09, 2008, 07:04:02 PM
Pirate -  thanks for the link to Goldmine.  Prices are great.
I found this circuit board that looks very interesting.
http://www.goldmine-elec-products.com/prodinfo.asp?number=G16565
Do you think it would be worth experimenting with?
should work fine for you. i have a similar circuit, slightly larger, taken from a scanner and it has no problem lighting a 2 foot 20 watt tube and the 8 watt shown earlier.
edit: this circuit seems to accept a wide range of input voltage, from 9V  to 16V. i didn't try any higher voltages. in this photo it is running off a 12V 1.2 Ah battery
Pirate88179
@ Wilby:
Powered by what?  Don't tell me it is a single AA bat. (grin)  That is a lot of light there, man, that is cool!  Do you have any idea how long this will work given the power source?  I mean, can you imagine going camping and everyone else is using candles and small LED lanterns, and you hang those tubes from a tree branch powered by a small battery?  This would freak the other campers out I am sure.  They would be looking around for your generator.  Nice work.
WilbyInebriated
Quote from: Pirate88179 on December 10, 2008, 02:33:27 AM
@ Wilby:
12V 1.2 Ah battery. you really could hang these vertically, the red croc clip on the right side doesn't have to be connected. the brightness drops a bit when this is done.
no idea on the run time. i think last time i checked the circuit it pulled about 250mA, but that was with the scanner tube, which also makes a great camp light. i have one made from old blank dvd containers and a scanner tube/circuit.
i like your diffuser on your film canister JT!
Freezer
Interesting way to refract the light bill.  :)
I tried the jt posted by jenna, and found it works without a resistor if you use 2n5089 in place of the 2n3904.  It draws about 32mA at 0.86v for 3 various leds.
