Joule Thief
0 Members and 102 Guests are viewing this topic.
dasimpson
ok i am cheating here i have got my joule thief to pull no more then 7 - 10 milliamps by putting a resister in line with the postive feed ok the led on the secondry is dimmer now then it was befor what i am hopeing is more winds will bring this brightness back up what do you think
btw i used a pot to ajust the resistence will i got the ampage draw below what i wonted then mesuerd with the multi meter then checked all the risisters i have for a similer reading
ok scrap that 10 times thew turns and same brightness oh well 100 milliamp draw it is then just hope it dosent raise to much with each led i add
gyulasun
Bill,
I do not know them, nor their prices but they have decade resistor boxes:
http://www.ietlabs.com/decaderes.html
Similar boxes exist for capacitors too, but you could also easily assemble such boxes on component prices: you need some ten way rotary switches (Yaxley) and resistors and a box. Regardless of member dasipson... if you need such boxes.
rgds,  Gyula
jeanna
Quote from: dasimpson on May 24, 2010, 09:14:17 AM
btw i used a pot to ajust the resistence will i got the ampage draw below...
See what gadgetmall did.
He put a capacitor on the unused end of the pot and joined the other side to one of the sides.
I am not exactly sure.
He then was able to use a 50K pot and get bright light on only 3 or 4 mA draw.
I only recently learned this, and have not tried it except in a flaky way.
When he first described it, I did not follow what he was doing, but I am sure it is a very worthy direction to go.
And if you get some way to describe it, please do, since this is something almost none of us have explored.
thanks,
jeanna
dasimpson
it is knowing exactly were he put them ius the problem with a diagram i could proberbly understand but i am very limited on parts i try and salvage al i can as i have as much money going out as i have comming in i think my main mistake was buying bc337-25 transistors insted of the 2n3904 but my intention at first was to build single joule thief and not the way of secondry winds and thing i guess when i get a little cash spare i will order some 2n3904 then my work would be on the same curcuit compnents to what most of you use
i know this wrighting must look like a load of rambling with no . and , etc but i am dyslexic and have alot of problems with wrighting and spelling but hay albut albert einstein was also and look how he did
Quote from: jeanna link=topic=6123.msg242383#msg242383 A=1274739655
thanks,
jeanna
jeanna
OK that is fine
(dyslexia makes you more flexible of brain IMHO  ;) )
Here is a copy of one such diagram from gadget who also called himself fusionchip.
If you look at the base resistor you will see the pot with the arrow.
It also has a cap symbol.
This is where he put the cap on the non used leg of the pot.
I was wrong. the mA were 0.43mA or micro amps... really low!!
BTW, you can expect the amps draw to LOWER when you put more lights on the secondary... just a little piece of magic to inspire you.
Here is the pic.
jeanna
