Joule Thief
0 Members and 64 Guests are viewing this topic.
resonanceman
Quote from: Pirate88179 on June 04, 2010, 09:51:50 PM
Gary:
Duh!  Now why didn't I think of that? ??? ?  I feel like an idiot.
Would the 2.7 volts in the B-cap be too much for 2 x 1.2 volts (2.4 volts) in the rechargeables?  If that is OK then this is a brilliant, and simple, solution.
Thank you,
It should  be almost ideal.
Remember  your  charge voltage has to be higher than your battery voltage to push the electrons   in.
gary
Pirate88179
Thanks guys.  I will give this a shot when I can.  It may take a while to charge them but...I don't care, it will be free.
Thanks again.
dasimpson
i would test with your dmm to what milliamps you get then go online look up battery charge caluclator that should give you an idea to how long
Pirate88179
I can get up to 3,000 amps when running it through the b-cap which is why I need to be careful as you mentioned.  The EER puts out a pretty consistent 19 mA's or so.  But, when running through the cap the spikes can charge it up pretty quickly (relatively speaking) so I will have to see if it can keep up...it may not.
It should make for a good experiment.
We will see.
dasimpson
you might find that the batterys pull the amount down the b-cap can store that the case with joule thief anyway
