Joule Thief
0 Members and 54 Guests are viewing this topic.
stprue
Found it, thanks Jesus  ;D
pg 5 on the SM TPU what we know so far thread if anyone is interested.
stprue
@Jeanna
Can you tell me what your jeanna coil consisted of?
winding style
turns
output in AC and or DC
jeanna
@wilby,
Thanks for that answer!
@stprue,
All my jtc's since almost the beginning have been made to use the jtc as the pulse generator.
I rarely ever use the C-E junction of the transistor.
I wound a 'secondary' on the same toroid that 'free-loads' off the magnetic pulses that happen with the normal operation of the jtc.
But to say one winding style is not possible, because it was the winding style I was playing with mostly.
Later it became clear that I needed to have the highest permeability toroid for it to work well.
I did the plain solenoid that xee2 suggested, and that worked very well. It was very unidirectional, meaning the pulses all went up.
But, it lit a cfl, which was the goal at the time.
I made some with the coil going back and forth as MK1 suggested. These gave a generally higher frequency. Sometimes these would choke the coil, but when they were working well, they were awesome.
These made the pulses go both ways, up and down in various ways.
In the end I modified the MK1 style to have a more UN-even distribution of winds (still 4 ways as his were,) and it gave me the best results.
I thought it was called AC when I began, but later, I learned that it was really pulsed DC all along.
But, that is what Tesla was experimenting with the whole time after he patented the AC generator. He felt it worked better.
(We still have not figured out all of what HE knew 110 years ago. Isn't that amazing?)
I hope this helps.
jeanna
cletushowell
Look ac is dc the sooner you figure that out the sooner you
understand photon
the measurement of ac and dc is a illusion of a open loop
When there both running there is no difference
the ground is the frame eliminate the open loops in either you
see there the exact same power both photon energies
infact you wont understand but ill say it anyways
theres no negative power at all
the only way you can find a negative power is to break the loop
so it only exist when the system is in
the state of between magnets or
open battery measuring photon with a volt metter is like sticking it to a stove burner or a magnet and saying how much power do we have it doesnt work
if you want me to continue i will but most shut me out in two sentences
to complicated I gues. They did a good job of covering up free energy
for 100 years its not we dont have it
they intentionaly stop it
stevenchiverton
 :) heres one of some i made, but the best joule thief was the easy to make battery charger one  which can allso recharge those tiny watch batteries and desulphate dead slr batterys and allso charge a photo flash capacitor to  ill add that soon
***Photo size edited by Moderator***
