Joule Thief
0 Members and 23 Guests are viewing this topic.
kb24
Quote from: j037m on December 19, 2010, 01:13:19 PM
(on diode text ) wrong cut. cut the other side not
that one look at the broo xee pic that provided
(on resistor text) when removed the neon i put the
other end of the tube on that place were the
neon is so locate were the neon  and put the
other end of tube there and on that same line
look if one of the resistor is on that spot
meaning that spot is the right
side of the tube to be connected and as i
can see here this is the one im telling you
now if this resistor is same circuit on the neon
you just removed then connect the other tube here
follow the line and connect the other end of tbe there.
==thats the text on the pic diode side and resistor side==
;Djoey
wana ask bout diode thing. After i cut off one of diode leg, so i just leave those cut off leg like that? what should i do with it?
kb24
;Djoey
test with this circuit but my output is to multimeter to measure the voltage but the voltage seem to be 0. But one thing i notice is that transistor become very hot. Any idea what's wrong?
j037m
Quote from: kb24 on December 20, 2010, 11:53:21 AM
no the transistor must not become hot ... also did you follow this attach pic which i give the link on the first post i give to you coz you must follow it like the jumper .. notice the battery outlet if on your  fuji circuit you dont have holes look on this picture provided and see were the oter side of that jumper connected meaning thats the right line even theres no hole on it ..
;Djoey
note : removed the diode dont use it coz the way i see your picture you using it by soldering it to your wire and connecting the tube on it on my circuit i cut it but didnt use it instead i leaved it there but remain cut and the wire i put is solder to the uncut side of diode.. just look on the picture on my first post link you will see the difference on it and on yours hope this help..
kb24
Quote from: j037m on December 20, 2010, 02:11:13 PM
;Djoey
from my circuit, i couldnt found any hole or line for me to put jumper on it as u can c from the diagram. Any idea on where should i put those jumper?  ???
should i remove the diode cut leg or i just leave it there?
thanks
j037m
Quote from: kb24 on December 20, 2010, 11:28:43 PM
thanks
look on this  and follow maybe this works coz i look on my diagram and the jumper is line with the one im pointing on the pic i provided
joey
