Joule Thief
0 Members and 681 Guests are viewing this topic.
DimaWari
Kindly check your toroid windings polarities and its better to use germanium transistor i guess.. I hope this will help you
kb24
Quote from: nievesoliveras on December 25, 2010, 03:37:11 PM
@kb24
Now some transformers come with the windings different.
Where suppose to be a 1 there is another number.
You have to check continuity and sketch a schematic of the transformer you are using.  Maybe you have to take out one from another fuji and learn from it by measuring.
Jesus
i have go to other town to search for different or older fuji camera but couldnt find any.. can anyone tell me which wire should connect to which part? coz the middle wire between primary is confusing
dasimpson
kb 25 you connected this wrong
it should of been connected to the resistor to the side of it
kb24
Quote from: dasimpson on December 26, 2010, 10:20:45 AM
too bad, i have disassemble all component from the circuit already.. so trying to connect all by using wire.
i try to connect my component according to diagram from josepino but i mess up with transformer pin.. i try compare my circuit with josepino diagram i notice a different in it.. any idea on which component should be connect to which transformer pin?
dasimpson
Quote from: kb24 on December 26, 2010, 10:38:11 AM
if you still have everything just put them back on like the photos and test if i had the same unit i could help you more
