Joule Thief
0 Members and 90 Guests are viewing this topic.
Pirate88179
The Josepino site is for an AA bat.  You have a AAA board which is totally different.  Please do not confuse these 2 boards.
j037m
kb the one on josepino has 4 pins on the other side and 2 on the other side of the transformer the one you show has 3 on both side  if the circuit didnt give you any good result maybe one of the parts is not working good or the way i see it you have different transformer my suggestion is before you open the new fuji circuit you will buy try to disect that old circuit like what i do and look if any of those is been not working good also look on the transformer if you really have 3 and 3 pins on it..
dont worry you can make it theres a lot of person here that can help you ..
;Djoey
dasimpson
Quote from: kb24 on December 26, 2010, 10:38:11 AM
too bad, i have disassemble all component from the circuit already.. so trying to connect all by using wire.
i try to connect my component according to diagram from josepino but i mess up with transformer pin.. i try compare my circuit with josepino diagram i notice a different in it.. any idea on which component should be connect to which transformer pin?
the bottom 3 pins is the middle one to the left one the same resistance reading to the middle and the right if so if you use the left and right pin for the reading is it double the single reading
if so i would use that for the joule thief side also make sure that they is no reading to the top 2 pins
dasimpson
infact i think an image with all the ristance readings on might help us help you make use of that transfomer
nievesoliveras
Quote from: aaron5120 on December 25, 2010, 11:51:47 PM
Hi Jesus,
I did what you suggested. I blew a led purposely for this experiment, and then connect it to the circuit. See the attached photos. No improvement. The load( a big LED) kept drawing down the battery. I tried with cap paralleled or seried with the blown led antenna, and nothing improved.
Any ideas besides everybody to help this to work out?
Thanks and happy holidays!
aaron5120
I have not been able to make it work either.
Only God knows what is happening.
But there is a circuit from @slayer that deals with wireless stuff. It can be used to charge the battery with its energy radiation.
I am lost now.
Jesus
