Joule Thief
0 Members and 102 Guests are viewing this topic.
dasimpson
Quote from: j037m on December 30, 2010, 06:07:50 PM
are the fuji circuit and kodak funsaver are the same coz i think the one that kb has is a fuji transformer and the one bro dasimpson has shown is kodak transformer.. also bro kb you said you already remove the fuji transformer on the circuit board can you check if it really has a 5 pins on it coz i just buy new fuji circuit and it has same 6 pins on it when i removed it i bought it on 7 eleven store .. one of the 6 pins looks like no connection on it but it has connection..
if you look at the first 30 pages i think it is of thies thread alot of work is done around the cam units
j037m
Quote from: dasimpson on December 30, 2010, 06:47:13 PM
thanks bro i just thought its not same coz when i try the first time doing  the camera circuit i buy the kodak and not knowing that im following the circuit of fuji so it end up on me busting up my kodak circuit lolz.. thats the time i ask bro bill and he give me pointers on how to do it .. and it work... by the way look on my new and first time ..hahahaha jt circuit on you tube ...
http://www.youtube.com/user/j037m#p/a/u/0/lNndpd38Wzw
kb24
oh i have 6 pin on my transformer.. but i think only 5pin are connected(not so sure)..  maybe wat u say is correct that it actually do connected.. May i know u buy which model of cam? mine is superior x800.. Is ur transformer stated DS64?
Btw, if u can run ur modified fuji circuit, would u mind post up ur circuit board? I will buy new cam and modify it once again. Thanks  ;D
freepow
@ All...
Something That I am going to make, not sure if it will work, but it should...
Look at the diagram, it is a simple Bendini circuit with a coil running the CD-disk with magnets, which will
start turning when Bendini is on, then as the CD turns, its axle turns a DC motor, and placed around the CD magnets is 2x pickup coils for extra power.
So then as soon as the Bendini is on and CD turns which turns motor, we will have power from 3x places...
1- motor,  2- coil (A),  3- coil (B).
Then we switch either coil (A+B) on, or switch motor on, and this power will go to the bendini circuit, then we switch off the 1xAA or CAP, and the bendini should keep going ????????
Then we can use the extra power coming from the motor or the coils (A+B) for something else.
What does everyone think ??????
dasimpson
Quote from: freepow on January 01, 2011, 07:23:28 AM
@ All...
Then we switch either coil (A+B) on, or switch motor on, and this power will go to the bendini circuit, then we switch off the 1xAA or CAP, and the bendini should keep going ??? ??? ??
What does everyone think ??? ???
you need to use a low rpm motor i have done this with cd and hdd units the rpm are to high to get any real power
i tried this exactl experement and failed i was wlays putting more power in then i was getting out
example i drew 200ma but i could only put back 100ma for this to be a success you need to put back in what is drawn out or over
