Joule Thief
0 Members and 179 Guests are viewing this topic.
nievesoliveras
Happy new year!!!
Hello @gadgetmall.
Is this schematic correct? It needs the bifilar turns number.
Also to verify if the toroid is 22 turns bifilar.
Jesus
dasimpson
i was just re reading the thread when i cam to the resistance substitution wheel and thos we could mek one with a breadboard one side of the resister all go to the same place but the other side has a wire we move up or down the hole for each resistance
gadgetmall
Quote from: nievesoliveras on January 07, 2011, 10:10:17 AM
Happy new year!!!
Hello @gadgetmall.
Jesus
Hello Jesus ! Yes that is correct on my mod to lasersabers joule ringer and calling it fusionchip gadget lightsaber battery reguager 3rd mod :) . I am waiting for 10000uf  caps but right now it reguages the battery and 2200uf cap  for very long cfl light . Also i have another one where i use just the HAZENS torroid and it has a secondary . Do you remember Hazen? It was a long time ago but he wound some pretty coils and i lost the winding turns on it but i wound a few and saved them . Well I replaced the bifialar coil alltogether with the hazens coil torroid and that is the one i have in the corner i am testing  as of now . It works good at reguaging and so far 29 hours and plenty of power . the one you drew works even better with lights saber coil _ hazen coil i tested a day ago and its good for running and reguaging(drawing hardly nothing meter wise )while its running . I counted 22 turns and that is 11 wraps red and then 11 wraps green and tie the center together . i now run the led from the secondary but dont put this one up yet until i figure out what i am doing on the hazen coil version without the lightsaber coil. ok . Nice schematic . I knew you would get it first time . :) Thank you man . Happy new year
Al
osiris
So
tell me why it lites....
yawn  ill tell you  :D
ever pulse a floro bulb .. and touch it ... ?  it is merucry vaper ?  lol
kick it it kicks back ONLY BIGGER
sounds like me !!!
i charge 2 boost caps in 5 min .. it runs my  130 lumens led for 5 hours ...
osiris
if i hook up 2 more caps ... it will blow the diode OFF THE BOARD !
;D
i was able to charge 2 boost caps 1 time with a 4007 diode befor it burnt out and filled the shop with smoke .. it litterly rolls smoke in seconds ..  :o
so should an engineer check out my work ...  i expect an engineer to be schooled properly befor they try to tell me how my shit works ..
i want the engery calculated properly  this means .. the temeiture of the  output diode  the temp of the coil the amount of energy consumed and the output ..
aint too much to ask ..  is it ?
no more dumb engineers !
so if you saw the wires im useing you all would say impossible to pass  however many watts in so many seconds over cat5 wire ...
the wires bairly get warm ...
it will be contained inside a rf amp case ...
gadget ..  get an inductive amp .. and HEAR THE MESS YOUR TOY MAKES ..
have you managed to land loose electrons on close by tools yet ?
or door knobs ?   bet youll only open the door and never know what happined
http://www.overunity.com/index.php?topic=10205.msg269985#msg269985
nievesoliveras
@gadgetmall
Do you mean this one?
