Joule Thief
freepow
@  ALL, Here is my recent experiment...
Run battery 1xAA rechargeable - running joulethief  @12K - running LED dim - charging supercap 50F.
Test results :                             RUN BATTERY(while running JT)          SUPERCAP
3:54 PM  Mon AF/Noon   Millivolts        1198                                            5.2 (empty)
4:28 PM                                         1181                                         572
5:04 PM                                         1187                                         627
5:31 PM                                         1189                                         650
5:46 PM                                         1190                                         660
5:54 PM                                         1190                                         664
joulethief  Res changed back to 20K
5:55 PM                                         1191                                         667
6:10 PM                                         1192                                         672
6:46 PM                                         1193                                         687
6:57 PM                                         1193                                         690
7:28 PM                                         1194                                         701
8:01 PM                                         1196                                         710
8:12 PM                                         1196                                         711
8:24 PM                                         1196                                         714
8:26 PM joulethief  Res changed back to 12K
8:29 PM                                         1196                                         715
8:46 PM                                         1196                                         719
8:49 PM joulethief  Res changed back to 10K
9:19 PM                                         1196                                         727
9:29 PM                                         1195                                         730
9:29 PM joulethief  Res changed back to 20K
9:35 PM                                         1196                                         731
9:48 PM                                         1197                                         735
10:09 PM                                        1197                                         737
7:41 AM TUE Morning                       1200                                         792
8:36 AM                                        1200                                         795
9:55 AM                                        1200                                         801
12:40 PM Lunch                               1201                                         810
1:20 PM                                        1200                                         811
I need to reduce RESISTANCE greater than 20k now, to stop run battery from decreasing a little, so I can either keep it at 1200 or increase it a little.
If you keep an eye in the run battery and charge cap, you can stop run battery from going down at the same time increasing charge cap !
0
gadgetmall
Good work freepower . you remind me of me a few years back . I did the exact same thing.
gadget
freepow
Thanks Gadgetmail...
Funny thing is this, I then used the charged cap and used it on the joulethief to light LED and it lit nice, so just for fun I short circuited the Cap to empty it, so I could see if it would charge up again on the same
rechargeable AA.
Run battery running joulethief - lighting LED - charging empty Cap gain
1:49 PM  1197 mV                                                   42.7 mV  (fairly empty)
1:53 PM  1142 mV                                                 381    mV
2:01 PM  1161 mV                                                 476    mV
2:10 PM  1169 mV                                                 528    mV
2:28 PM  1175 mV                                                 576    mV
3:02 PM  1179 mV                                                 618    mV (charging up nicely)
It seems I can charge the cap up the second time and the same run battery in recovering again !
My circuit go's in a circle, run battery run's joulethief lighting LED charging up cap and cap go's back into run battery again and starts over again.
gadgetmall
YEs freepower exactly what i was doing . see the thread Second Stage Joule thiefs and you will see Ground loop actually made a circuit to keep the bcap charged up to its volts then run a load then drop its volts back into the AA run battery . I still have faith in it .
Gadget
freepow
Hey gadgetmail are you the one who has cancer ? sorry for asking!
Why dont you keep on with this experiment further too ????
And lets make it happen !
