Joule Thief
0 Members and 90 Guests are viewing this topic.
freepow
@ ALL,     I have seen  rechargeable  "C" batteries rated at  9000 mA's  and  "AA" rated at  3000 mA's
              Does anyone know the maximum current I can charge these at with a solar panel ????
Can I charge the  "C" batteries with a  3 Amp solar panel ??
Can I charge the "AA"batteries with a  3 Amp solar panel ??
What minimum volts do I need to charge  2x AA battery rated at 1.25v each ????
FreeEnergyInfo
dasimpson
here is a list for you
1.2v                  2-2.5v
2.4v                  3.5-4v
3.6v                  5-6v
6v                     7.5-9v
12v                   15-18v
10% of there capacity so the 9000mah would be 900mah for 15 hours 30% counting losses
3000mah would be 300ma for 15 hours i have 2500mah batterys and i charge them on my charger for 16 hours at 250ma
what you could do is use a zener diode to dump the excess current off to a load to stop over charge this was how the old motorcycle electrics worked
Quote from: freepow on February 13, 2011, 05:26:22 PM
Hi  NickZ,  can you tell me what your JT's are using in mA's from your AA's  ,also can you post some pictures of your lights and JT's.
I have a great small box that has a 240v wall socket in it that I can plug a nice 240v(20xLED) bulb lamp with cord into it, and the jt is powered by 2xAA.
A question for you...  if I was to charge 2xAA's  how many volts would I need from a solar panel ???
What would be the fastest I can charge 2xAA's ?? (the max current I can charge with) ??
dasimpson
if your panels put out such high current you could leave the units on 24/7 and the batterys would still be charged for the night
dasimpson
nick would you use a voltage devider to run the jt as thats how i was thinking of doing it but on the other hand i dont think they be need to use a jt with a 12volt system
