Joule Thief
0 Members and 27 Guests are viewing this topic.
dasimpson
the jt i have at moment has an output of 30volts so i can run 9-10 leds at full brightness if i try and run the same amount of leds in parallel the brightness drops i havent dont a longivity test with more then one led i may try with 9 in series ad see how that works
dasimpson
i use wide angle led also they have like a hole drilled in the top here is an image they can put out quite a bit of light
sorry for bad qality not much light and i was using my phone
NickZ
   @ All:
    Here are some pictures of the Jt circuits that I'm working on now.  The last ones are of my captret lighting 12 leds, the small Jt is solar powered.
                                        NickZ
dasimpson
lol i have the exact same yellow and white toriods dident have much luck with them tho maybe it is because i am using cat5 cable
NickZ
   The yellow ones are not the best toroids out there, but the price was right, (free). They are fine for getting to know a little about toroids, and what they can do, without spending anything on ferrites.
   I think it can be done with big air cores, without the cost of buying big expensive 6 inch or bigger ferrite coils.
   I'm going to wind a big bifilar air coil on a clear 2 inch hose, and connect the ends with a dowel to form a circle. Wind a bunch on turns on it, and see what it does.
  Looks to me that for a given voltage on the Jt, the bigger the bifilar coil, the greater the output.  Anyways, a big air coil with a thousand turns of 30 gauge magnet wire should work.  Why not?   I'm aiming for the Jt-TPU,  but , would like to see some current too, not just flufffffff.
                                                        NZ
