Joule Thief
0 Members and 82 Guests are viewing this topic.
Neuromacer
Does anyone know what happened to Watson's blog?
I tried to access the site this morning and it doesn't exist anymore. Any information??
watsonseblog.blogspot.com/
Pirate88179
@ Leaninggreen:
Thank you for posting the new link with the photos and also, thank you for your kind words.
LeaningGreen
kooler
i know this isn't a joule thief..
but the jt folks are more likely to use this than the desk jockeys.. out there..
if you use 9 volts and higher use a small 90v neon bulb with a diode to the battery..
if tuned right you can double your run time.. this is a ferrite core from a junk flyback coil..
i used a dual pot but it measures 2.2 k .. puts out a mod sine wave..
transistors or mosfets work.. fet have a cleaner sine wave..
the trick here is to not use the batterys voltage so use a diac , sidac , or even gas discharge tubes rated high than your battery volts.. just catch bemf back to the battery on the side that the transistor is in the off position so the volts feed back go in the battery and not the coil..
robbie
robot797
Quote from: LeaningGreen on October 11, 2011, 06:22:23 PM
For those of you that use the fuji or kodak type circuit Goldmine has them on sale for $0.49 ea!
http://www.goldmine-elec-products.com/prodinfo.asp?number=G17610&utm_source=Goldmine&utm_campaign=fe7d19f680-Sept10&utm_medium=email
i live in holland so i cant order some (only paypall i has no creditcard)
can somone order me 30 i will pay back
