Joule Thief
0 Members and 119 Guests are viewing this topic.
Groundloop
@xee2,
The oscillator is close to an Hartley oscillator. It is a low waste
configuration because the base current is "recycled" through
the power coil. So it is easy to get close to 100% efficiently
with this circuit. If I increase my output coil to approx. 700 turns
then this circuit should (in theory) be able to light up a string
of led bulbs. But my goal right now is to see if I can get some
ferromagnetic resonance in the Ferrite core, and see if this
resonance does anything to the delivered output power.
Attached is my next try. I will use some diodes to clamp down
the transistor and give the high voltage spikes some path to
go. This will probably protect the transistor from blowing up.
[EDIT]
I have tested this circuit now. Now I have a "well behaved" circuit
that runs stable and the transistor does not blow up. But I also lowered
the efficiency a lot. Needs almost 2,5 Watt to fully light the 1,8 Watt LEDs.
Not good. :( I can also see on the spectrum analyzer that the circuit no
longer is a wide band oscillator, as it was.
GL.
Groundloop
Hi,
This circuit is better but still waste too much power.
I need 2 Watt to fully light the 1,8 Watt LED bulb.
GL.
Groundloop
Hi,
I have tested this circuit. I did use a function generator
and tried all frequencies from 0 to 5MHz. Did not detect
and change in the output from the circuit. Next test will
be making an extra coil for the function generator input
and test again.
GL.
Groundloop
Hi,
I have wired up this circuit. The first thing I noticed when I
connected the high voltage to the Ferrite core is that I got a
low light output in the LED lamp EVEN WITH THE CIRCUIT
POWER SWITCHED OFF!
Next thing I did was to switch the circuit on with a low
input voltage (10V @0,08A) and then switched the high voltage on.
The LED bulb light did get dimmer with the high voltage on.
The research goes on.........................
[EDIT] The LED bulb lighting up with only high voltage was due to
           dielectric leakage between the Ferrite core and the coils.
GL.
powercat
Hi GL,
If you can get close to that 100% Try feeding the light energy into a solar cell,
it has been tried before on this thread some time ago, to many pages now to find it ;D
Also there is a new thread where this is already being tried
http://www.overunity.com/index.php?topic=11686.msg305277#new
Vid
http://www.youtube.com/watch?v=i5K11dCgulY
all the best
cat
