Joule Thief
0 Members and 222 Guests are viewing this topic.
NickZ
   Gadget, Lasersaber, and All:
   I've also got a bit of good news. I was just able to light the big 65 watt Clf BRIGHTLY, as well as all my other Cfls, and leds, although the neon, or incandscents will not kick on, yet. All I really care about for now is lighting the Cfls.
I'm tempted to add more turns on the secondary, and primary also. This is still using the 3 inch ferrite rod, 400 turns of 30 gauge for the secondary, and  20 turns 14 gauge primary. It zapped me several times, so I really got to watch the secondary output now, as it's no joke anymore.  I replaced the small transistors with the MJE 3055 again, to have another go at it. And, guess what?  NO HEAT, Even on 15 volts, and less than 500 mAs, from a wall adapter, or from a 12 volt battery.
Now for some unknown reason its working kick ass...  It's also an Exciter, but will not light anything off of the additional 2 inch Exciter tower, just the Av plugs, even though it has a strong wireless field up to about a foot away from the circuit or tower.
  This is one awesome circuit, and it costed me,  well,   Zilch.  As that was all I could afford to spend on it. Ha!
   I'll post some more pictures later tonight,
  Thanks  Lasersaber!!!
stprue
Quote from: gadgetmall on October 04, 2012, 03:04:28 PM
I got it !!  I took the other new rod and wound 1080 turns of number 26 then taped it . Then i wrapped 370 turns #20 on top of it and taped it . I can now light an incandescent filament with 1.2 volts and transistor runs cold ., BUT running over 12 volts blows the transistor . due to high voltage . I blew three 2n3055 and one tip3055 , SO now is where i need to put some resistance in this circuit and probably a neon to protect the transistor . It's KILLER !! about 10.5 it lights an unmodified 120 vac cfl  unmodified leds lamps 60 watt light bulbs and in my opinion i should be able to loop it with a cap  .. no time for pics right now maybe tonight when i figure out how to tame this powerful ls circuit ..
Crowclaw it is lasersabers circuit . I am just modified it to run on one battery . see a few post back for his diagram . he has no base resistor just an 8 inch special ferrite fat rod and one layer then another layer for the primary . It is an awesome circuit one you get the wire length right . right now i think i have too much but i like it that way . when i saw the 110 volt 60 watt filament glow on a rechargeable aa i am happy . i let it run for 15 mins and there was hardly no drop in volts still 1.2  :) This is unconventional . puts watts out for milliamps . Oh i also have a strong magnet attached on one end . it make it brighter .
Gadget
This is very exciting stuff congrads.  15 min with visible light in bulb and no decrease in 1.5 volt AA very nice.
synchro1
Quote from: NickZ on October 04, 2012, 05:30:59 PM
                                                               "No Heat"  working kickass!
The reason there's no heat from the transistor is the thermal conversion taking place on the quantum plane that generates the demag power. The ferrite core is leaching the transistor heat through the wires to do the work required to realign the electron orbits. The heat's transfered at the quantum  level, so the wires show no ordinary signs of warming as they would through conventional thermal conduction.
stprue
@ LS
Pembroke!  If you live near this town I'm right down the street from you!  Shoot me a PM.
synchro1
Here's a patent by Heinrich Kunel for an overunity "ENERGY LINEAR GENERATOR" identical to Gadgetmall's SUPER JR 3. Note the long ferrite core, the primary and secondary wraps, the magnet on the end and the "Circuit breaker". This patent's 34 years old.
