Joule Thief
gadgetmall
Quote from: sohei on November 25, 2012, 03:02:52 PM
Greetings to all.
After few experiments using the earth ground and the metal frame from the window, I am now convinced that indeed it is increasing the "power" for the circuit. Please correct me if I am wrong. After testing few standard transformers I found one that light a 9w modified CFL and the led bulb was with great light too. When connecting the cable from the window, the amount of light increase.
Follows the test:
http://youtu.be/SOzTnN7mlVw
Regards,
Max.
I saw the same thing last night hooked to a ground rod outside and a long wire on one of the load wires . it does get brighter but i didn't check the volts then .
@Gadgetmall: your germanium diodes are likely either 1n34a or 1n60. The 1n60 is a bit more robust and sometimes won't work in a crystal radio where a 1n34a will, there may be a slight difference in the fwd voltage spec.
It's getting hard to find germanium transistors for me; 2n2635 is a PNP, available as NTE160, but that's about all I can find any more.
http://www.datasheetarchive.com/2N2635-datasheet.html
Wooohooo.... try MPSA18 in place of the 2n2222 in the low voltage Ghostlight and JT modes !!
gadgetmall
totoalas
http://laserhacker.com/forum/index.php?topic=70.msg714#msg714
LET THERE BE LIGHT  THIS XMAS   FOR TYPHOON SANDY VICTIMS
