Joule Thief
DreamThinkBuild
Nice work Groundloop.
Looks like an energy harvesting circuit.
Patent:7791557 - Multiple antenna energy harvesting
http://www.google.com/patents/US7791557
Groundloop
My conclusion so far is that this circuit do work. But one will need a long outside antenna and
a good earth grounding to get a output that can be used to charge batteries etc. So a good antenna
and good grounding, and there you go, free energy. (Minus the cost of the circuit:-)
GL.
stprue
@Groundloop
Read about Jes's version!
QuoteAs with all free-energy devices, the exact
constructional details are vital.
Can't argue with that !!
Groundloop
Quote from: stprue on January 02, 2013, 10:55:58 AM
@Groundloop
stprue,
Thank you for the document.
There was a part of the document that did not sound right. (See attached)
Two modules can power a LED to full brightness at 2.6 Volt. Let us say that the
current to fully lit a normal LED is 20mA. Then, P = (U*U) / I = (2,6*2,6) / 20 =  0,338mW.
That was for two modules, so one module can then provide 0,169mW.
Then the article goes on to say that you can fully charge a 12 Volt battery with 20 modules
over night. 20 modules is 3,36 Watt. If it is a very small battery, then yes, but if it is a large
car battery, then no way. (20 modules can power 10 LEDs.)
Then the article goes on to say that with a estimated of 200 modules, you can power your house.
You can power 100 LEDs with 200 modules. Nowhere close to powering a house.
To conclude, yes the ambient power module do work. But the output of each module
is low, typical 0,169mW. To power a house you will need an afoul lot of modules to
get enough power.
That said, I plan to make an 24 Watt (approx.) module. Attached is the Eagle CAD design files.
The 24 Watt module has 144 single modules onto a printed circuit board. I use 12 modules
in series and the 12 of the series modules in parallel. The work on this has begun but the soldering
is a pain in the ass. 576 diodes and 576 capacitors to solder, so 1152 solders in total. A lot of work. :-)
The PCB and parts did cost me approx. 6000 Norwegian Kroner. (Approx. 1088 USD).
I expect to get this board ready in a couple of months time. (I solder some few components each day.)
GL.
