Joule Thief
0 Members and 51 Guests are viewing this topic.
totoalas
ac neu ground rf charger v4 040113  yt imtotob
using various caps diodes
totoalas :)
stprue
Quote from: Groundloop on January 03, 2013, 04:22:42 PM
TK,
The actual soldering goes fast. What is taking time is to put the components onto the board.
So a robot arm putting the components onto the board, and then to the wave soldering station. :-)
Seriously, if I was loaded with money I could order a factory to solder my boards. I'm not, so
hand soldering is the only option.
>>You might need as many antennas and ground connections as you have modules, in order to get the full advertised power.
If collecting RF is your only theory regarding this circuit, then yes, many antennas etc. But I think it is more to this
circuit than just collecting RF. So I will try out a really large metal plate also. But as I said, this project will take time.
I will only find time to test the metal plate(s) next summer.
GL.
To test once it gets warm, you can go to a remote area free of most radio waves to see what effect it has on the receiver circuit.
stprue
Quote from: TinselKoala on January 03, 2013, 05:22:02 PM
I'd like to know other people's results from switching the ground and antenna hookups. Preliminary testing of my single module using 1n34a diodes seems to be telling me there's no difference.....
Tomorrow I'm going to erect a large metal plate (actually a roll of heavy duty aluminum foil) up in the attic. We have a metal roof, so that should be interesting..... Maybe I'll hook a wire to the roof itself, even though it's attached to the house, it's a huge area of sheetmetal....
And there is a huge difference in my mind between "overunity" performance and harvesting some of the energies that are constantly swirling around us.....
Hello TK,
Sounds like some goods ideas to try but remember that most of the inventors/copiers recommend insulating the plate from touching the mounting as well as the plate itself.
stprue
Quote from: totoalas on January 04, 2013, 03:17:54 AM
Ac neuground rf charger v3 04013   yt  imtotob
Still cannot connect ou in my deskstop sorry about that
71V dc in 12 mins
Totoalas
@all
Something seems strange about this circuit to me.  I'm very surprised at the output.  Do you think that there is a energetic coupling happening between the AC neutral and the hot wire since they are side by side????
Any thoughts on this?
totoalas
hi
earth  water pipenetwork
water in pipe from reservoir  bodies of water
totoalas
