Joule Thief
MarkE
The solution is really quite simple.  When you reverse C and E you change the circuit from common emitter with a relatively high output impedance to common collector with a low output impedance and in either case current flow stops when the base is not more than 1 Vbe above the emitter (NPN).  The transformer acts as a 2:1 autotransformer between the LED side and the transistor base side.  As the base voltage increases, the emitter voltage decreases and vice-versa.  As long as the initial voltage source is greater than Vbe, the circuit should be able to start. It should be able to hold down to Vbe/2.  Current through the E-C path of a forward biased BJT can flow in either direction.
Quote from: MarkE on October 27, 2014, 09:52:42 AM
Yep. As soon as I posted that schematic the "bulb lit up" in my brain. My understanding must be improving, thanks for your help.
Dave45
http://www.learnabout-electronics.org/PSU/psu31.php
http://www.learnabout-electronics.org/PSU/psu32.php
The boost converter is constantly pulling from the battery whereas the buck only pulls during the on time of the transistor.
MarkE
Quote from: Dave45 on October 27, 2014, 11:41:41 AM
That is true, but the JT and its variants use either a flyback:  discontinuous current at both ports, or boost: continuous input current / discontinuous output current.
Dave45
So could we use this to take high voltage ac bring down the voltage and boost the amperage.
