Joule Thief
0 Members and 168 Guests are viewing this topic.
synchro1
This photovoltaic cell 1000 times as efficient could couple as a Photonic reactor to the light mod circuit.
synchro1
A nested tetrahedron of photo cells and LEDS facing in on each other recycling power would deliver more output per mass and volume then a fusion reactor.
synchro1
The deodechedron consists of individual Tetrahedrons. The flat surface is superior to a spherical one. Nice shape for a "Photonic Reactor".
Quote from: synchro1 on August 07, 2021, 11:12:41 AM
A little overestimated ! The "1000 times" more are from 0,0...% basic conversion efficiency from ferroelectric material !
The MLU research findings  I see in correlation with Prof. Naoshi Ikeda et al. https://www.greenoptimistic.com/green-ferrite-solar-cell-japan-20110920/ findings !
crystal of RFe2O4
https://worldwide.espacenet.com/publicationDetails/description?CC=US&NR=2011168967A1&KC=A1&FT=D&ND=3&date=20110714&DB=EPODOC&locale=en_EP
[0117] Considering the voltage value of 20V/cm described above, for example, when the thickness of the crystal of RFe2O4 in the electronic device is 1 μm, the phenomenon of a change in state of electrons as described above is caused to appear by applying a voltage of approximately 2 mV to the crystal of RFe2O4.
Further, considering the manufacture of an integrated circuit by use of a device having such a property, it is possible to configure an electronic circuit which can be driven by several mV.
If a circuit can be operated at approximately 1/1000 of the voltage for a conventional transistor integrated circuit, to simply calculate, it can be expected that its power consumption is ( 1/1000)<2>, that is approximately parts per million in a circuit composed by use of the above-described electronic device, and the performance that its operation speed is thousandfold is obtained.
Sincerely
OCWL
synchro1
How much power would a 12 sided dodecahedron collector box of high performance photovoltaic cells generate over an extended run time with the 220 volt LED bulb fully illuminated inside?
A measurement of intensity in Lumans would permit the summation of theoretical power consumption. The comparison would deliver the  actual overunity COP.
