Joule Thief
Mk1
Artic_Knight
@ Jenna and MK1
i am having trouble replicating the 3 and 4 coil design, i am not getting any volts or amps! i checked the connections and the volt meter said its fine. any inputs?
@ Bill
how did you set up that earth battery led and cap? im having trouble replicating that too!
i must be an air head tonight as i cant seem to get any of the projects to work. got the joule thief to use 15mah while at full brightness though!
Mk1
@Artic_Knight
You need a little faith, Don't let your meter fool you .Just connect some led to it!
You can also connect it to a diode bridge , If you need you meter .
Artic_Knight
yea i just noticed that too LOL
now heres a question for ya, can you get this to work? it didnt do squat for me. i can get the LED to light on the secondaries but when i try to do something like this it fails to work.
edit: basically try to tap the secondaries to charge a cap to keep the unit running, its a test of overunity.
Mk1
@Artic_Knight
Ok , first the coils 3 and 4 are not connected to anything in the circuit except your load or a diode bridge.
It just a regular jt with 2 additional coil.If you can light the jt led you are all set.
This is the funniest thing nobody gets it , yet It so simple,Don't complicate stuff.
Don't worry i had to repeat many times already, Everyone want's to connect them to something , you are not the first or the last to make that
mistake .
Btw , your plan look like Lidmotor jt.
Mark
Edit: If it works the led , make a quick test, take any wire you got make one turn and connect a led to it.
